Master has a new set of machine guns and antenna for the Panzer I
In the MASTER GM-35-099 set, you will find two barrels for the MG13K machine guns and an antenna for the first tank of the Panzerwaffe – the PzKpfw I. The set is designed to be universal – it can be installed on any available 1/35 scale model, including those from Tamiya, Dragon, Tristar, and others.
To accurately reproduce all the details of the MG13K machine guns in 1/35 scale, the barrels themselves are made from turned metal, while their cooling jackets are high-quality 3D resin prints.
The antenna was divided similarly: the mount/base is a resin print, but the antenna rod itself is a turned metal element. This makes the antenna durable—and perfectly detailed!
This photo shows the level of detail on the MG13K machine gun – for 1/35 scale
The assembled elements from the MASTER GM-35-099 set installed on a 1/35 scale Panzer I model
