FM25-010 is a 1/35 Panther Ausf. G towing cables and towing hardware 3D print set for SLA printers, featuring true wire-rope strand-by-strand detail, correct end fittings, and a print-friendly spool layout with supported files included. Designed as a clean, high-impact aftermarket upgrade for the parts you actually see — compatible with all common Panther G kits.
Your Panther Ausf. G just got the final touch that instantly upgrades the whole model: realistic tow cables with a true wire-rope look — strand-by-strand detail — plus the correct towing hardware.
This set is built for clean, reliable printing and a finished, authentic installation without compromises.
🧰 FM25-010 | Panther Ausf. G Towing Cables is now AVAILABLE
👉 Cults3D: https://cults3d.com/@FaustusModels
✅ Key features
  • True wire-rope texture — individual strands visible
  • Aftermarket-grade look — straight from your SLA printer
  • Print-Friendly Spool Layout — easy print, fits any common desktop SLA printer
  • Supported files included (plug & play) + unsupported parts (full control)
  • Heat-formable cable option: warm briefly (hot water / gentle heat) → route naturally → cool down → holds shape
✅ What’s included
  • Two cable sizes
    • Small towing cable (14mm / 15m)
    • Main towing cable (32mm / 8.2m) (full length + end loop options)
  • Correct end fittings & routing options
    • Full spiral cable option + straight cable option
    • End loops + open end pieces
  • Complete towing hardware
    • Standard shackles (open/closed + pins)
    • Towing C-hook
    • Panther heavy-duty shackles (open/closed + pin)
  • Rear hull towing cable holders (2x)
  • Bending jig for consistent, clean shaping
✅ Two workflows included
  • Presupported “plug & play” files (fast, reliable printing)
  • Unsupported single parts (custom orientation, full control)
No hunting. No “close enough” parts.
Just print → clean → install → DONE. 💥
📌 Compatibility
Fits all common Panther Ausf. G kits, including:
  • Das Werk
  • Takom
  • Border Model
  • and other compatible Panther G variants
Digital files: Cults3D.com/@FaustusModels
RT-Diorama shop: rt-diorama.de
