M151 Shmira/Djapas
panorama
Germany
KitMaker: 254 posts
Armorama: 253 posts
Posted: Thursday, May 30, 2013 - 10:20 AM UTC
Back again.
After a long abstinence from modelling some progress was achieved on the little fella.
The second chair was constructed and the antenna sockets were build anew.
A wash to bring out the details followed which frustrated me for it either didn´t emphazie the details or gave the base color a brownish hue I didn´t like. I think next time I will use a dark grey as a wash with this base color.
The tires were weathered:
Next the whole vehicle received another wash with various tones of light brown and cream to imitate sand and dust deposits.
And that´s the way he looks now with some gear thrown into it.
Some details und stuff still require paint and patience (only to be covered afterwards with pigments ;-) ) but the end is in sight...
flugwuzzi
Lower Austria, Austria
KitMaker: 633 posts
Armorama: 599 posts
Posted: Friday, May 31, 2013 - 03:04 AM UTC
Michael,
your model is looking excellent. great to see the progress.
cheers
Walter
Trisaw
KitMaker: 4,105 posts
Armorama: 2,492 posts
Posted: Friday, May 31, 2013 - 05:14 AM UTC
Wow, very detailed and the color looks great! Nice job!
panorama
Germany
KitMaker: 254 posts
Armorama: 253 posts
Posted: Tuesday, July 02, 2013 - 09:52 AM UTC
This little *`)&/% Mutt is driving me crazy right now. After half a dozen failed attempts to write the MLCs on the right rear fender freehand I finally gave up and bought Stencelit-masks.
Attach mask, spray, done. That´s at least what I thought.
In real life tiny and bent surfaces with no place to stick the mask and the necessity to combine masks and thus to align the digits prevented a satisfactory result so far.
I would have shown you a pic but flickr takes tooooo loooong to upload right now, so I will add them later.
Better times will come again. They allways do! For today I quit. See you around.
Michael
panorama
Germany
KitMaker: 254 posts
Armorama: 253 posts
Posted: Friday, July 05, 2013 - 09:56 PM UTC
other things worked out better.
Some chipping was done. Scratches were colored in light grey. Deeper ones were emphasized with dark grey. The center of the grey received a touch of brown. Edges with some wear like at the fuel tank or the battery cover were touched up with a graphit pen.
Thanks for looking, keep tuned.
flugwuzzi
KitMaker: 633 posts
Armorama: 599 posts
Posted: Saturday, July 06, 2013 - 06:16 AM UTC
Its coming really, really nice ... great work michael.
cheers
walter
panorama
Germany
KitMaker: 254 posts
Armorama: 253 posts
Posted: Saturday, July 06, 2013 - 09:20 AM UTC
Danke Walter!
After all this fiddling and frickle stuff I needed something more coarse for a change. So I started working on a little diorama for my Mutt.
The base is a plane photo frame.
1.0 mm PE sheet is the material the frame is build from (2.0 mm would have been better. 1.0 mm is not sturdy enough).
The rough shape of the landscape was formed using styrofoam and styrodur sheets and plates.
Here the stuff I used for my first diorama. Most important the book of Lazlo Adoba. Worth every Penny! Apart from that, repair filler, various soils, stones, plants (artificial and natural) and - yes indeed - barbeque coal were applied!
And thats what I did with it: the coal pieces were pressed into the soft repair filler to resemble rock. The ground was covered with sieved soil. Some more stones were placed and amended by some plants. Finally the loose soil was fixed with diluted white glue.
The next steps will be priming, painting and weathering. I keep you updated.
Hope you like it. Let me know what you think. Any comments, tips, advice is appreciated. It is a first try after all.
happy modelling
Michael
rfbaer
KitMaker: 1,866 posts
Armorama: 1,696 posts
Posted: Thursday, July 11, 2013 - 04:39 AM UTC
Most excellent work on the Mutt, wear and tear looks exactly like the examples I saw there 15 years ago.
I also like the start on the base, should be very nice.
panorama
Germany
KitMaker: 254 posts
Armorama: 253 posts
Posted: Friday, July 12, 2013 - 06:02 AM UTC
Thanks Russel,
it would have been even nicer if wheels and tracks in the sand would have pointed into the same direction:
So, have a good laugh on my expense.
Think I will try to redo just the flat part of the base. Hopefully without messing up the rest...
Cross your fingers.
Michael
panorama
Germany
KitMaker: 254 posts
Armorama: 253 posts
Posted: Friday, July 12, 2013 - 10:05 AM UTC
Change of subject:
most of the gear is done
Weapons:
The guns were painted black and wiped with graphite powder. Plastic parts were coloured semi gloss black with a light black enamel wash to break the shine a little bit. Metal parts were emphasized a bit with a silver pencil.
Wooden Box with heavy wear:
The green base color was heavyly chipped with Vallejo dark sand in sponge technique. Actually this box would have been a good opportunity to practice hairspray technique. Well – next time.
Cooler:
White: Tamiya X2 washed with grey. Lights were painted with pure x2
Red: Tamiya X7, washed with a reddish brown, pin wash with the same colour, only more concentrated.
The bottles were scavenged from Mengs Pick up (Thank you Meng for putting all this stuff in!).
Quite some effort went into the little helmet:
To my knowledge there are three and four color helmet covers. I opted for the three color one and started with the base color (Iraqui sand and Medium olive from Vallejo ratio 1:1) according to the recommendation from Kevin Benson on http://www.idf-modelling.com/forum/viewtopic.php?f=15&t=23&start=10) he developed for a tanker vest. Sqiggles were added in brown and black.
All this was blended with repetitive dry brushings in light sand until I felt it looked right.
The inside was kept in green and the straps olive.
To create some depth and shine in the goggle glasses, they were primed glossy black (Alclad Primer) and colored shiny aluminum. Some idea of a reflective shine was acchieved by adding Tamyia Sky in several thin layers on the glass.
Combat ratio boxes:
These are the old IDF ones that are not in use anymore. The new “Manot Krav” contain food for 4 soldiers only while the old ones were designed to “satisfy” 5 soldiers. I do not know the time when the new ones were introduced and apart from that, to my knowledge there are only the old ones available (Plus model).
And last for now a radio from Tamiyas modern tank equipment:
That much for now.
Happy modelling
Michael
panorama
Germany
KitMaker: 254 posts
Armorama: 253 posts
Posted: Friday, July 12, 2013 - 10:18 AM UTC
flugwuzzi
KitMaker: 633 posts
Armorama: 599 posts
Posted: Saturday, July 20, 2013 - 02:42 AM UTC
Nice detail painting.
Looking forward seeing them all placed on your model.
Great work - Michael.
Walter
darreng
KitMaker: 789 posts
Armorama: 382 posts
Posted: Saturday, July 20, 2013 - 03:50 AM UTC
Fantastic work going on here
panorama
Germany
KitMaker: 254 posts
Armorama: 253 posts
Posted: Saturday, August 17, 2013 - 06:02 AM UTC
Thanks Walter and Darren for your motivationg comments. They came just in time to help me through this MLC painting on the rear fender:
Stencelit mask - second attempt: I finally managed to place the mask tight to the fender by bending it and securing it with white tack
only to achieve this sobering result:
Letters just a bit too big, alignment still poor. Not the way I wanted it to look.
So after sanding of the letters and touching up the white background back again to the good ol´ brush...
Ok, you´re right, the israeli conscript who painted it, probably had the last days of his term and did a lousy job on the old Djapas. We will cover it with some hefty washes and a lot, a lot of dirt and dust.
I hope this will have been the last tricky part of this build for me. I´m looking forward to load it, put pigments and the last few details.
Stay tuned and thanks for following
Michael
panorama
Germany
KitMaker: 254 posts
Armorama: 253 posts
Posted: Sunday, August 25, 2013 - 11:09 AM UTC
The last details have been added:
Legend and some spare PE sprues from Eduard supplied the metal parts for the seat belts. The belts themselves are Eduard masking stripes. Of cause any strips of tape would have been okay, but those stripes had just the right width.
And thats the way they look when coloured and in place:
The locks have been made from Evergreen-Stripes. A 0,3 mm hole was drilled and a 0,3 mm wire inserted. After coloring they were glued in place.
In daylight and with a recharged camera battery I will take and post some more pics.
Thanks for following.
Michael
flugwuzzi
KitMaker: 633 posts
Armorama: 599 posts
Posted: Sunday, August 25, 2013 - 10:51 PM UTC
Great work on the details, Michael.
Can´t wait to see your detail shots and the next update.
Walter
panorama
Germany
KitMaker: 254 posts
Armorama: 253 posts
Posted: Friday, August 30, 2013 - 05:34 PM UTC
Calling it done!
So here are some shots of this little fellow in its last days in Israeli reserve service bevor being replaced by some Humvees.
So thanks for stopping by and particularly for your encouraging words on the way.
Here are the pics:
flugwuzzi
KitMaker: 633 posts
Armorama: 599 posts
Posted: Sunday, September 01, 2013 - 03:05 AM UTC
Congrats, Michael.
You did a phantastic job on this model. It looks absolute great!
Walter
panorama
Germany
KitMaker: 254 posts
Armorama: 253 posts
Posted: Sunday, September 01, 2013 - 09:38 AM UTC
Hi Walter,
I do appreciate your feedback. And thanks for the compliments. On one hand I am quite aware of the shortcomings of my built but on the other I have to admit that I am definitaly not unhappy with the my little Djapas. I particularly like the last picture, which was taken at my balcony in bright sunlight and which I think catches the feel of this little jeep as I remember it quite well.
I´ll keep you updated on any progress on the little diorama but now - after all this fiddling stuff - I need something completely different. Something big, something with wings, something with large areas to let my airbrush roam..
Maybe something like this:
Well...
Wish you a good start into the new week. Model on!
Michael
TRM5150
Massachusetts, United States
KitMaker: 2,159 posts
Armorama: 707 posts
Posted: Sunday, September 01, 2013 - 09:50 AM UTC
Great job there Michael!! Love the jeep and where you are heading on the base!! Laszlo's book is great isn't it? He has a knack for showing how to lay down a nice base with little effort!! Keep up the nice work!!
panorama
Germany
KitMaker: 254 posts
Armorama: 253 posts
Posted: Tuesday, November 11, 2014 - 08:37 PM UTC
Well, other projects got priority, so progress was halted for a while. But now I can present some work on the base:
For my first "rocky" base I stuck to a technique published in Art of Modelling Magazine featuring a LMTV-build.
So, as described there the base was coloured black after priming.
Then a coat of buff was applied.
The small plants/bushes received a shades of green.
Some parts of the rock and some individual stones were coloured with various enamels.
Some dark brown washes blended everything together.
To my taste the blending was a bit too much and I do not like the brownish tone of the base as it is right now either. So either I will try to achieve a lighter shade by applying Pigments or give it another brush with buff. Don´t know yet.
windysean
Wisconsin, United States
KitMaker: 1,917 posts
Armorama: 735 posts
Posted: Tuesday, November 11, 2014 - 11:35 PM UTC
Awesome effects all around! You've really taken the time to do every part right. (and I'm glad I'm not the only one to try lettering a bumper so many times, then just give up and paint it by hand! )
Well done!
-Sean H.
C_JACQUEMONT
Loire-Atlantique, France
KitMaker: 2,433 posts
Armorama: 2,325 posts
Posted: Tuesday, November 11, 2014 - 11:40 PM UTC
Looks shiny, maybe just a coat of matt varnish could restore the balance?
I must add You've done an awesome job so far.
Christophe
Trisaw
Posted: Wednesday, November 12, 2014 - 12:11 AM UTC
Great work! Your detail on such a small vehicle is amazing!
