Dioramas: Making Bases
Discuss all aspects of making bases.
Warping Dio Base > Time for a Change!
Grauwolf
#084
Quebec, Canada
KitMaker: 2,485 posts
Armorama: 743 posts
Posted: Monday, May 11, 2020 - 11:22 AM UTC
Thanks, Robin.
I did notice that the product description claims that it dries in 30 minutes,
which is a plus as Celluclay apparently takes forever to dry.
ctkwok
Alabama, United States
KitMaker: 197 posts
Armorama: 183 posts
Posted: Monday, May 11, 2020 - 12:16 PM UTC
I second sculptamold as I picked up the tip from Andy's hobby hq. It doesn't shrink at all.
steviecee
KitMaker: 123 posts
Armorama: 31 posts
Posted: Monday, May 11, 2020 - 01:49 PM UTC
look up Roman Khramov's videos and how he uses just a thin layer over foam board. Beautiful work. Heavy layers crack over time and any surface can get moldy
deathdork
KitMaker: 314 posts
Armorama: 296 posts
Posted: Monday, May 11, 2020 - 06:45 PM UTC
I actually use a 50-50 mix of Celluclay and Durhams water colored with kids poster paint. Does not shrink.
Have fun!
GeraldOwens
KitMaker: 3,736 posts
Armorama: 3,697 posts
Posted: Tuesday, May 12, 2020 - 07:53 PM UTC
I used Celluclay just once. Not only did it shrink and warp, it became infested with weevils (I live in the sunny tropics, aka insect heaven).
I also prefer Durham's Water Putty. Doesn't shrink, and adheres well without any glue. Available in Hardware (DIY) stores, it comes as a dry powder in a can. Build up terrain features with plastic foam, and then mix up Durham's to a consistency like pancake batter and apply it. Follow this with a powdering of dry Durham's straight from the can, which will soak up excess water from the surface, and create an instant, gritty earth texture. You can embed other materials to vary texture or simulate plants, if you like. The putty dries to an earthy, tan color, so no white spots if your paint coverage is uneven. You can also add water-based paint or dry pigments to the mixture to color it all the way through.
