Armor/AFV: Axis - WWII
Engine Vent Cover for Panther A in Italy
hj1985
New South Wales, Australia
KitMaker: 62 posts
Armorama: 62 posts
Posted: Sunday, February 02, 2020 - 08:34 AM UTC
HI guys, I'm making a Reg 4th Panther A in Italy. But I am not sure which engine vent cover I should use. Any idea?
Grauwolf
#084
Quebec, Canada
KitMaker: 2,335 posts
Armorama: 643 posts
Posted: Sunday, February 02, 2020 - 10:22 AM UTC
You can use this build as reference:
http://davestankworkshop.blogspot.com/2013/03/panther-ausf-1pz-regt-4-florence-italy.html
GeraldOwens
KitMaker: 3,629 posts
Armorama: 3,590 posts
Posted: Sunday, February 02, 2020 - 03:40 PM UTC
If you're referring to the round grills over the engine fans, either or both would be correct. It appears the spiral pattern came first (replacing the preproduction spiral pattern with the "complicated" edge design in late spring of 1943), but the radial pattern appeared shortly after, either due to a change order, or perhaps just reflecting different vendors for the part. By the time the late Panther Ausf. A reached production, there were stocks of both grill types on the production lines and both were used interchangeably, sometimes in mixed sets (with no preference as to which version went on which side).
hj1985
KitMaker: 62 posts
Armorama: 62 posts
Posted: Tuesday, February 04, 2020 - 12:01 AM UTC
Thank you guys
