Armor/AFV: Axis - WWII
HB Brummbar Early Lower Hull Front shapes?
BornToDig
Maryland, United States
KitMaker: 344 posts
Armorama: 310 posts
Posted: Thursday, January 02, 2020 - 04:43 AM UTC
Hello all,
I'm building Hobbyboss' Brummbar, which I understand is a reboxing of the tristar kit. I don't know if the instructions are a direct copy as well, but they're somewhat vague in spots.
I'm confused about how the applique plates on the front lower hull should look. There are five pieces here. The 20 mm armor plate and the applique plate which goes over it, and then a smaller applique plate that goes beneath the 20 mm armor. Then there are two small inserts (plastic or PE) which go on either side. The applique plates have cutouts and dont reach the sides of the hull. I have a few brummbar pics and do not see these cutouts on any of them.
Also the small inserts that go along the sides are shaped differently on the instructions, and their location is vaguely indicated. They don't fit into the wedges on the hull tub.
If anybody has this kit built, can you please post a photo of what the finished lower hull front is supposed to look like ?
marcb
Overijssel, Netherlands
KitMaker: 1,102 posts
Armorama: 1,087 posts
Posted: Thursday, January 02, 2020 - 09:41 AM UTC
What kit number do you have?
80134,without zimmerit
https://www.1999.co.jp/eng/image/10346410
80135, with zimmerit
https://www.1999.co.jp/eng/image/10353002
I haven't built the kit, but it might help if you first install the drive sprockets.
alanmac
KitMaker: 2,996 posts
Armorama: 2,917 posts
Posted: Thursday, January 02, 2020 - 09:54 AM UTC
Hi.
Is it section 3 that you are having difficulty with? Looks straightfoward to me with a choice of PE or plastic for the two crescent shaped sections that back onto the drive sprocket housing filling those notched gaps in the applique armour.
marcb
Posted: Thursday, January 02, 2020 - 10:05 AM UTC
BornToDig
KitMaker: 344 posts
Armorama: 310 posts
Posted: Thursday, January 02, 2020 - 10:46 AM UTC
Hi.
The problem is that the plastic parts do not resemble the drawings in the instructions.parts wf 15 and 16 are shaped differently and don't extend into the notches on the applique.
I'll try adding the sprocket housings first, as per Marc's suggestion.
BornToDig
KitMaker: 344 posts
Armorama: 310 posts
Posted: Thursday, January 02, 2020 - 10:55 AM UTC
Interesting. Here are the kit parts in comparison. Maybe the drive housings will enclose this business on the sides?
