Campaigns: Active Campaigns
Hosted by Richard S.
Akitsu Maru build
steviecee
KitMaker: 75 posts
Armorama: 24 posts
Posted: Wednesday, January 01, 2020 - 02:57 PM UTC
I've started my build of the Akitsu Maru and hopefully can make quick progress. This is my first blog so please bear with me
All the sprues laid out.
Drilled out the holes shown in step 2 for the braces for the weapon sponsons on both sides of the hull and for the large sponson that support the island (only one side shown). I also drilled out the holes at the stern for the stern mounted boat davits. The instructions show 1 more hole to be drilled out but i could not find in the instruction a part fot that location so I left it closed
The superstructure assembled and the main and lower deck and hull halves cleaned up and ready for assembly
CMOT
Staff MemberEditor-in-Chief
KitMaker: 10,862 posts
Armorama: 8,523 posts
Posted: Thursday, January 02, 2020 - 12:38 AM UTC
I hope the hull goes together easily as I can see that being a pain otherwise. The hole that you cannot see a part for, I would put a mark where you can see it just in case
bison126
Correze, France
KitMaker: 5,129 posts
Armorama: 5,004 posts
Posted: Thursday, January 02, 2020 - 07:57 AM UTC
Good luck for your build. But are you sure Armorama is the right forum to post it?
Olivier
steviecee
KitMaker: 75 posts
Armorama: 24 posts
Posted: Thursday, January 02, 2020 - 01:03 PM UTC
Good idea about marking the hole and you're right that autorama is the wrong place, so perhaps one of the nice moderators would kindly move it for me
steviecee
KitMaker: 75 posts
Armorama: 24 posts
Posted: Monday, January 06, 2020 - 02:54 PM UTC
The hull glued together. The large locating tabs on the deck and hull sides made getting everything aligned easy.
The rear hinge plate for the rear doors. After a quick no problem test fit I glued it on. You can put this part on upside down if you are not careful and it needs to go on before the bottom plate.
steviecee
KitMaker: 75 posts
Armorama: 24 posts
Posted: Thursday, January 23, 2020 - 03:17 PM UTC
Been away because of family needs but the next step is to clean off and up all the ejector pins on the flight deck supports and other parts (examples shown). Given the recessed details on many parts they are probably needed.
