Armor/AFV: Axis - WWII
RFM Jagdpanther Ausf. G2 Build Log
d111298pw
#456
Oklahoma, United States
KitMaker: 654 posts
Armorama: 638 posts
Posted: Saturday, September 07, 2019 - 09:51 PM UTC
Sub-step A23 is next. This assembles the Jack. RFM provide you the option to display the jack "in use" for a roadwheel change diorama, or similar.
For my build, it will be stored on the back plate.
Instructions
Parts
You can cut J76 to the length you need if using it in a diorama. If you are going to build in the stored position, cut this part at the line in the yellow circle. DO NOT remove the pin, circled in red, as this is required for attaching it to the back plate.
Assembled
I'll paint all the tools at one time at the end of the build.
d111298pw
#456
KitMaker: 654 posts
Armorama: 638 posts
Posted: Saturday, September 07, 2019 - 10:33 PM UTC
Next are the rear mounted storage boxes, Step A23.
RFM give you both styles of boxes used on the late G2's. The primary version is with the "X" pattern (G10/G12). The version with the horizontal ribs (G15/G19) was used, but not on a lot of vehicles. Box G16 is for the Panther IR equipment and is not used on the G2.
Instructions
Parts
Assembled
d111298pw
#456
KitMaker: 654 posts
Armorama: 638 posts
Posted: Saturday, September 07, 2019 - 11:20 PM UTC
The last of the sub-steps are for the right and left exhaust muffler. The late G2's all had the flame suppressing mufflers. RFM also includes the hoods. However, you don't need to install them unless you want. Not all vehicles were built with them and they easily got knocked off in the field.
Instructions
Parts
Assembled
Now, we can start assembling the rear panel.
d111298pw
#456
KitMaker: 654 posts
Armorama: 638 posts
Posted: Sunday, September 08, 2019 - 12:21 AM UTC
Finally starting on the back panel. Step 53 adds cover plates and brackets. The jack and wire cutters will be added later after painting.
Instructions
Parts
Assembled
d111298pw
#456
KitMaker: 654 posts
Armorama: 638 posts
Posted: Sunday, September 08, 2019 - 02:01 AM UTC
Continuing with more tool brackets on the lower back panel. The instructions shows both shackles as part J60. This isn't correct. One is J55, the other is J60.
Instructions
Parts
Installed
d111298pw
#456
KitMaker: 654 posts
Armorama: 638 posts
Posted: Sunday, September 08, 2019 - 02:55 AM UTC
Completing the back panel with the addition of the storage boxes and exhaust mufflers. I have left the exhaust hoods off at the moment. I still haven't decided if I'll use them or not.
Instructions
Parts
Installed
I haven't glued part J28 yet, as I need to install the jack later. So, I have used Microscale's Micro Liquitape. It holds the part in place and is then easy to remove.
d111298pw
#456
KitMaker: 654 posts
Armorama: 638 posts
Posted: Wednesday, September 11, 2019 - 04:47 PM UTC
I'll be travelling for the next couple of weeks. So, new updates will happen after I return on the 25th.
d111298pw
#456
KitMaker: 654 posts
Armorama: 638 posts
Posted: Thursday, September 26, 2019 - 03:19 AM UTC
I'm back from my trip down under and back at work on the build.
Step 56 doesn't have many parts. The rear panel, from Step 55, is installed along with the lower storage box supports and the rear tow hooks.
Instructions
Parts
Painted and installed
The tools and jack will be installed later.
This completes the assembly of the lower hull. Next you start on the running gear.
d111298pw
#456
KitMaker: 654 posts
Armorama: 638 posts
Posted: Friday, September 27, 2019 - 12:07 AM UTC
Before getting to Step 57, you have a number of sub-steps dealing with the roadwheels, drive sprocket assembly, idler wheel.
I'll start with Step A26.
Instructions
Parts
RFM gives you the internal gears that provides you many options for a maintenance diorama.
Assembled
The level of detail is excellent.
Since this is a very late war version (April 1945), the skid (G36/37) is used in place of the return roller. However, if you want to build an early 1945 version with the return roller, you can. The return roller is part C14.
d111298pw
#456
KitMaker: 654 posts
Armorama: 638 posts
Posted: Friday, September 27, 2019 - 12:27 AM UTC
Time to get to the roadwheels, drive sprocket, and idler wheel. I'll be leaving all the parts on the sprue to do the primary painting. Once this is completed, I'll complete steps A27 through A31.
Instructions
RFM has given you one of each style of roadwheel for use in a diorama. These are in Steps A28 and A30.
Parts
d111298pw
#456
KitMaker: 654 posts
Armorama: 638 posts
Posted: Friday, September 27, 2019 - 01:56 PM UTC
I have completed Steps A27, A29, and A31.
Here are the double roadwheel set for Step A27.
Be careful when installing the polycaps into C8. I show you here the correct and incorrect way to install them. The polycap opening needs to be installed "face down"
Completed
Step A29 assembles the Idler Wheel. No real issues with this one. The idler represents the late 665mm dia. version.
Step A31 assembles the Drive Sprocket. Again, this is the late version. No issues with the assembly.
Time to install all of these sub-assemblies.
d111298pw
#456
KitMaker: 654 posts
Armorama: 638 posts
Posted: Friday, September 27, 2019 - 10:37 PM UTC
Time to start adding roadwheels. Step 57 adds the inner roadwheels, drive sprocket gear assemblies, front tow hooks and two PE brackets.
Instructions
Parts
The fit of roadwheel C1 is very tight on the axles. I decided to open the holes just a bit to allow them to fit easily. I used a #41 drill bit to do this.
Parts Installed
Everything fit nicely.
d111298pw
#456
KitMaker: 654 posts
Armorama: 638 posts
Posted: Friday, September 27, 2019 - 10:42 PM UTC
Step 58 adds the Drive Sprocket, Double Roadwheels, and Idler Wheel.
Instructions
Parts
Installed
The roadwheels fit easily as these use polycaps.
d111298pw
#456
KitMaker: 654 posts
Armorama: 638 posts
Posted: Friday, September 27, 2019 - 11:31 PM UTC
Step 59 adds the outer roadwheels.
Instructions
Parts
Installed
The running gear is now complete. I'll attach the drive sprockets after the tracks are assembled.
d111298pw
#456
KitMaker: 654 posts
Armorama: 638 posts
Posted: Saturday, September 28, 2019 - 11:23 PM UTC
Step 60 starts the roof panel assembly. This version of the kit has the roof as a clear part. That gives you the option of leaving it clear and being able to view the interior. Or, you can paint it. I'll be leaving it clear for my build.
Instructions
I started with sub-steps A32 and A33
Parts for A32/33
One of the handles (L20) disappeared on me. So, I scratched a replacement from .5mm wire.
Parts for the step
Assembled
No real issues here. The hatches don't fit together that well. But, it's good enough for me.
d111298pw
#456
KitMaker: 654 posts
Armorama: 638 posts
Posted: Sunday, September 29, 2019 - 09:35 PM UTC
Getting closer to the finish line. Step 61 continues with the roof assembly.
Instructions
Parts
Installed
It's easy to loose that tiny pe bracket, Y86. No real issues here.
d111298pw
#456
KitMaker: 654 posts
Armorama: 638 posts
Posted: Sunday, September 29, 2019 - 10:15 PM UTC
Step 62 finishes the roof assembly.
Instructions
Parts
The instructions tell you to connect Y29 and Y79 with a wire through the hole. If you elect to do it this way, a .2mm or .3mm wire should be used. I elected to glue the parts together as I won;t be having the assembly moveable.
Assembled
Next up are the tracks.
d111298pw
#456
KitMaker: 654 posts
Armorama: 638 posts
Posted: Monday, September 30, 2019 - 10:52 PM UTC
The main focus of Step 63 is the assembly of the tracks.
Instructions
I'm not attaching the superstructure at this time. I haven't decided how I want to display this once it's finished.
RFM also includes the option to build the track assembly tool for a diorama.
RFM also includes ice cleats (X4) for a winter build. The instructions also show these are part X7. That is not correct. Only X4 is the cleat. You are only given seven on each X Sprue. In reality, these were installed on every 5th to 7th track link. For 87 links, this would require 12-18 ice cleats per side. RFM hasn't given you enough to assemble correctly.
Parts
Track Assembly Jig - Glue the two parts together and it will hold 11 links.
You need to be careful of the orientation of the links. Otherwise, you will assemble them backwards. Here, I show the correct and wrong orientation.
Here are the first 11 links in the jig
You have two types of pins, X14 & X15. Which side you install these determines if it is a left or right side track. X14 is the outside pin. The pins are grouped in sets of five to make is easy to install.
The assembled first run for the right side.
Test fit around the Drive Sprocket
Place the complete link into the first spot on the jig. Then place the next links to complete the second run.
Continue doing this until all 87 links are assembled.
The tracks are designed to be workable. You need to carefully place a drop of glue at the head of each pin. Too much glue, and the track won't move. I use a pin to place the drop.
This is a slow process that can't be rushed.
d111298pw
#456
KitMaker: 654 posts
Armorama: 638 posts
Posted: Tuesday, October 01, 2019 - 04:31 PM UTC
I've completed the right side track and the test fit was good.
On to the left side track, and the spare links.
GazzaS
#424
KitMaker: 4,648 posts
Armorama: 2,248 posts
Posted: Tuesday, October 01, 2019 - 05:21 PM UTC
Mark,
Been a while since I checked in. Everything looks great!
d111298pw
#456
KitMaker: 654 posts
Armorama: 638 posts
Posted: Tuesday, October 01, 2019 - 07:12 PM UTC
Mark,
Thanks
d111298pw
#456
KitMaker: 654 posts
Armorama: 638 posts
Posted: Wednesday, October 02, 2019 - 02:16 AM UTC
I've completed the left track as well.
And the spare track links
Time to paint.
trahe
KitMaker: 1,158 posts
Armorama: 950 posts
Posted: Wednesday, October 02, 2019 - 06:40 AM UTC
Looking good! I like the interior detail!
d111298pw
#456
KitMaker: 654 posts
Armorama: 638 posts
Posted: Wednesday, October 02, 2019 - 11:33 PM UTC
Thanks Thomas
d111298pw
#456
KitMaker: 654 posts
Armorama: 638 posts
Posted: Wednesday, October 02, 2019 - 11:35 PM UTC
The tracks have been painted and installed
The next step is the last one for the build. I then need to finish painting the tools and install them.
