Armor/AFV: Techniques
From Weathering to making tent rolls, discuss it here.
Reason for using primer? when, when not?
SdAufKla
South Carolina, United States
KitMaker: 2,238 posts
Armorama: 2,158 posts
Posted: Wednesday, March 13, 2013 - 04:29 PM UTC
I was ONLY trying to learn.........
Regards
Jay
Don't sweat it, Jay.
Try it both ways and see what works best for you and your preferred painting materials and techniques.
As for myself, I've been building armor models non-stop for almost 50 years, and I never regularly prime vehicle models.
I do always wash my builds before I start painting - ordinary liquid dish detergent, warm water and a soft water-color paint brush. This removes sanding dust, swarf from sawing and drilling, and other building "schmutz" along with oils (I use a lot of 4x0 steel wool) and mold release agents, etc.
I only use acrylics (mostly Tamiya, but also other brands) and have absolutely no problems with paint adhesion even for models that are decades old. Zero, zip, nada - no problems at all.
(For example, I have a Italeri Pz I with "On the Mark Modeling" PE, built ca. 1988, an IPMS Nationals first place winner, that hasn't lost so much as a flake of paint in all these years...)
I am very careful in how I handle and how much I handle my models as I'm painting them. I always wash my hands before I sit down to do any painting and deliberately try not to handle things more than necessary. (Greasy pizza finger prints, dirt, etc. on your hands will leave blemishes in your finish. Even if you think your hands are clean, they probably aren't clean enough to handle a painted model...)
Having said all this, though, I always prime my figure models with Tamiya flat white before hand brushing the acrylic undercoats, but that's entirely because I want to ensure that I get the exact colors that I want on these undercoats.
If you find that you're rubbing the paint off your models as you finish them, then maybe you need to prime or handle the models less. If you find that the paint stays where you put it, then maybe you don't need to prime. If you find that you need so much paint to get good color coverage that you're hiding the details, then maybe you need to prime so that you don't need so many extra color coats...
I'd say, when or when not to prime depends more on you than on what anyone here says.
HTH,
ChrisDM
KitMaker: 717 posts
Armorama: 697 posts
Posted: Wednesday, March 13, 2013 - 10:14 PM UTC
A big +1 from me on the last few posters Jay.
If you ignore the bickery stuff there is some really great advice on here for and against priming
As Mike, myself and others have said; try it out
Modelling is about experimentation. Forums can give you pointers on what to try and how, but when it comes down to it you really only find out by application on real models on your own bench
Try a few things; good luck, and let us know how you get on. Preferrably with pictures
bpunchy
Western Australia, Australia
KitMaker: 366 posts
Armorama: 199 posts
Posted: Wednesday, March 13, 2013 - 11:48 PM UTC
I like to use the Tamiya grey rattle can primer .
Its cheap , and very fine .
Light coats , let it dry between .
Eloranta
Hame, Finland
KitMaker: 286 posts
Armorama: 195 posts
Posted: Thursday, March 14, 2013 - 01:15 AM UTC
This.
joepanzer
KitMaker: 803 posts
Armorama: 740 posts
Posted: Thursday, March 14, 2013 - 01:59 AM UTC
Yeah, man. Experiment. I've never used primer, but it looks like it helps with the recessed areas of the model-around hatches, deep depressions, etc. I'm looking forward to giving it a try.
As far as McKeever goes, by his own admission:
"I consider myself firmly in the intermediate stage, with lots of room for improvement"
nuff said
McKeever
KitMaker: 246 posts
Armorama: 172 posts
Posted: Thursday, March 14, 2013 - 03:39 AM UTC
nuff said
Way to take things out of context. Know who usually passes the ny bar--those who feel a little uncertain about it afterwards. Humility more often than not proves to be most beneficial in the endeavours of men.
joepanzer
KitMaker: 803 posts
Armorama: 740 posts
Posted: Thursday, March 14, 2013 - 03:45 AM UTC
Context? You're the one who claims that priming is a necessity and considers non-use "Unfathomable"
Keep reaching for the Thesaurus!
CameronForester
Arkansas, United States
KitMaker: 37 posts
Armorama: 36 posts
Posted: Thursday, March 14, 2013 - 04:23 AM UTC
Is priming a necessity? No, but it usually helps. That being said, I've had instances where it seems that oils in the plastic leached through the primer and affected the paint. I usually prime but not always. I've airbrushed Tamiya acrylics without primer, you just have to take care handling it. The same goes for Vallejo Model Color as both paints are pretty delicate.
To prime, if I'm building a tank, I usually find a spray can of red oxide primer. Tracks and any other subject usually receives a coat of the appropriate color of Krylon Fusion. I've applied everything from Tamiya acrylics to Model Master enamel to Tamiya lacquer rattle cans over Fusion with almost no problems (one issue on a Fujimi model with MM enamel Classic Black and I'm pretty sure it's something to do with the plastic).
McKeever
KitMaker: 246 posts
Armorama: 172 posts
Posted: Thursday, March 14, 2013 - 04:55 AM UTC
No thesaurus for me. I actually have a classical education. I'm washing my hands of this.
joepanzer
KitMaker: 803 posts
Armorama: 740 posts
Posted: Thursday, March 14, 2013 - 05:58 AM UTC
Yeah, and make sure your modelling area is well ventilated. Seems like you've had a bit too much primer.
CMOT
Staff MemberEditor-in-Chief
KitMaker: 10,954 posts
Armorama: 8,571 posts
Posted: Thursday, March 14, 2013 - 06:28 AM UTC
How about sticking to information and drop the baiting. enough already
joepanzer
KitMaker: 803 posts
Armorama: 740 posts
Posted: Thursday, March 14, 2013 - 01:29 PM UTC
Mein Apologies
Does primer help when painting faces on figures? I try to use artist oils and it seems like they tend to want to clump a bit.
hliu24
KitMaker: 798 posts
Armorama: 797 posts
Posted: Thursday, March 14, 2013 - 01:39 PM UTC
Thank you all, it is gonna take me a while to run through the whole thread with all the information.
jay
CMOT
Posted: Thursday, March 14, 2013 - 01:40 PM UTC
Thank you Joe
On the subject of figures and primer I have never primed figures before but having read through this thread it would seem to be a good idea.
c5flies
KitMaker: 3,684 posts
Armorama: 2,938 posts
Posted: Thursday, March 14, 2013 - 02:57 PM UTC
Jay, if you do decide to try a primer, you may want to give one of the colored primers a go, or use a darker primer to your advantage for shading. In other words, instead of adding another layer of paint as just a primer, use the colored one as a primer/basecoat or a shading base.
I never used primer on armor until I tried out the Vallejo acrylic primers. Prior to that the only time I primed was for a high gloss finish (auto's) or figures...and I still use Tamiya fine in the spray can for those. The Tamiya is excellent except for the odor...which is why I never primed armor
The Vallejo primers, for me, serve a few pluses:
Gives me an idea if the build is ok for the top coats.
Brings the styrene, PE, resin, aluminum, etc. to a uniform finish.
My top coats seem to go on thinner and smoother.
In short...when I didn't use primer I didn't have any issues with paint adhesion, when I started using primer I felt that the finish came out just that little bit better.
Just my 2 cents worth.
SgtRam
Staff MemberContributing Writer
AEROSCALE
#197
KitMaker: 3,971 posts
Armorama: 2,859 posts
Posted: Thursday, March 14, 2013 - 03:34 PM UTC
Mein Apologies
For faces and figure, I use Black spray, usually Testors. I find for me it gives a dark base to help with the shading.
tylusfaust
KitMaker: 371 posts
Armorama: 217 posts
Posted: Thursday, March 14, 2013 - 04:48 PM UTC
What's primer?
SdAufKla
Posted: Friday, March 15, 2013 - 02:39 AM UTC
Mein Apologies
Joe,
Check out this thread about painting figures with artist oils:
Armorama::Italian Ariete Tankers North Africa
If you have some more questions about it, maybe think about starting a new thread. This one has about run its course, and the topic of figure painting would be a large divergence from general priming.
