Battering Ram for IDF Armor?
AngryDog
Singapore / 新加坡
KitMaker: 1,114 posts
Armorama: 900 posts
Posted: Friday, September 23, 2005 - 03:22 AM UTC
Anyone have pictures or schematics of these used on the Centurion and Magach?
18Bravo
KitMaker: 6,526 posts
Armorama: 5,498 posts
Posted: Friday, September 23, 2005 - 06:07 AM UTC
Here's a scratchbuilt one on a Centurion:
And the top view:
Here's the Magach ram from AEF. You might as well scratchbuild it for all the trouble I had cleaning a simple casting like this. Mounting brackets and bolts heads had to be replaced.
Another view:
The Centurion one is based on photographs and I'm sure it's close to correct. I've only seen two front photos of the Magach ram but the AEF one looks right at least from that angle.
AngryDog
Singapore / 新加坡
Armorama: 900 posts
Posted: Friday, September 23, 2005 - 03:13 PM UTC
Excellent thank you,
Just to clarify.. the ram on the magach is positioned at a horizontal angle on slightly levitated?
What material is it?
That rectangular piece at the front (the ram itself!) on your centurion is painted black, Why?
So is it standard that the lower blazer modules are removed when the Ram is attached?
18Bravo
Posted: Saturday, September 24, 2005 - 03:23 AM UTC
Yes, the ram on the Magach angles slightly upward from the hull, whereas on the Sho't is is horizontal. I think all of it is just made of steel. The IDF went through red phases and black phases, painting fittings and other items, like towing shackles. I think the black just represents this trend. You can paint the one on the Magach black as well.
And yes, photos show the Blazer panels removed. The ram itself would provide excellent standoff from RPG's, and obviate the need for any ERA.
AngryDog
Singapore / 新加坡
Armorama: 900 posts
Posted: Saturday, September 24, 2005 - 03:44 AM UTC
Thanks! Now I can start scratch building it, hopefully I'll get the dimensions right, I've already 2 magachs built, one with Mine Roller, the other was with Dozer Blade until I found out it was incorrect, so now here comes the Ram for it. I'll post pics once I'm done.
18Bravo
Posted: Saturday, September 24, 2005 - 03:53 AM UTC
If you start by working from the towing lugs and building the mounts around them, I don't think you can go wrong. Good luck.
AngryDog
Singapore / 新加坡
Armorama: 900 posts
Posted: Saturday, September 24, 2005 - 05:30 AM UTC
Understood
jazza
Singapore / 新加坡
KitMaker: 2,709 posts
Armorama: 1,818 posts
Posted: Saturday, September 24, 2005 - 11:22 AM UTC
Surprised no one mentioned this but thats a fine looking Centurion by the way. The first photo just somehow had an immediate impact when you first look at it. I really like the way the armor is done.
AngryDog
Singapore / 新加坡
Armorama: 900 posts
Posted: Saturday, September 24, 2005 - 01:39 PM UTC
Sometimes, we come across a model and we've so impressed that we've nothing to say. But yes indeed, that's an outstanding model!!
schlicki2
Germany
KitMaker: 3 posts
Armorama: 3 posts
Posted: Monday, September 04, 2017 - 01:12 AM UTC
Hello, just one question! What was the battering ram for?
Greetings Schlicki2
ReluctantRenegade
Wien, Austria
KitMaker: 2,131 posts
Armorama: 2,062 posts
Posted: Monday, September 04, 2017 - 01:20 AM UTC
The mother of all zombie threads...
