Dioramas
Urban vignette/diorama 1:35
Bruc84
Slovenia
KitMaker: 69 posts
Armorama: 66 posts
Posted: Monday, March 16, 2020 - 07:14 PM UTC
Hallo guys!
I get the idea for this from the book Building dioramas from Chris Mrosko… I chaged it a little bit and i Will present the build here.
I needed some achitectural elements, and first i tried to do some molds from balsa... but it didnt work out... It was nearly impossible to demould theme and the were not precise...
At work i asced the CNC guys nicely… ok, lets be honest, I am their boss and in 15 min the mould positive from Aluminium was ready. So i made my first silicone mould withowt any problems...
I mixed some Herculite 2 plaster, poured the thing et voila… I use a vibrating table to avoid air bubbles
I needed a walking section so i made one from elements from plaster out of Diorama debries moulds...
The work goes on with the frame... (5mm balsa). evrything is tested for fitting only put togeather with masking tape... for 45deg cutting and sanding i use my home made device...
Bruc84
Slovenia
KitMaker: 69 posts
Armorama: 66 posts
Posted: Monday, March 16, 2020 - 07:51 PM UTC
I upgraded the frame for the 2nd level… i used 4mm balsa because i run out of 5mm
I started the facade… i used blue foam from Ak-Interactive and i must say that is money well spend… it carves verry nicely… other home foams dnt work so well
I made a texture roll. small cat litter rocks randomly glued on a cutboard roll, impregnated with thined white glue, and sanded of picks…
For the arcades i printed a 1:1 drawing and glued it doun on 1mm cartbord. i cut out the thing and added some texture with reparature stucco thined with white glue, applied with stiff brush
From the first mould i made plaster pieces for the top of the facade… i glued on some fine earth (like the texture roll) and made a new mould… here are the results...
KoSprueOne
Myanmar
KitMaker: 3,927 posts
Armorama: 1,455 posts
Posted: Tuesday, March 17, 2020 - 08:40 AM UTC
This is a very precise approach to structure facade building. I'm looking forward to how this all looks put together.
maartenboersma
Noord-Holland, Netherlands
KitMaker: 725 posts
Armorama: 703 posts
Posted: Tuesday, March 17, 2020 - 09:30 AM UTC
Looking good,
Nice to see another Plaster project.
18Bravo
KitMaker: 6,910 posts
Armorama: 5,834 posts
Posted: Tuesday, March 17, 2020 - 11:13 AM UTC
Zdravo. Nice work there.
Bruc84
Slovenia
KitMaker: 69 posts
Armorama: 66 posts
Posted: Tuesday, March 17, 2020 - 09:43 PM UTC
I made another mould for the whole walking section an I made a plaster copy…
Than I reduced the size in the mould with some playdoh-plasteline and made another small copy for the upper flor...
The upper flor was asembled with a resin cobblestone piece, a plaster piece and some stuff from Miniart…
Thanks for the compliments… If you have other questions dont hasitate to ask…
Stay tuned...
dhines
Nova Scotia, Canada
KitMaker: 389 posts
Armorama: 355 posts
Posted: Tuesday, March 17, 2020 - 11:44 PM UTC
Really nice start, I will follow with much interest.
Bruc84
Slovenia
KitMaker: 69 posts
Armorama: 66 posts
Posted: Wednesday, March 18, 2020 - 01:42 AM UTC
Looking good,
Hallo, Marteen…
Can you tell me wich plaster are you using for your projects?
Regards
maartenboersma
KitMaker: 725 posts
Armorama: 703 posts
Posted: Wednesday, March 18, 2020 - 08:18 AM UTC
Here you go ,
is see your Herculite 2 plaster is from the same brand
Bruc84
Slovenia
KitMaker: 69 posts
Armorama: 66 posts
Posted: Thursday, March 19, 2020 - 10:30 PM UTC
The fence is done (Miniart). I made the brackets (the screws are missing)
I added glass to the lamp... Any idea what type of glue to use to glue plastic glass (from a shirt box for example) to styrene?
Also the bracket for the lamp is done (screw missing)
Some gerneral improvement fotos…
Stay tuned
