Armor/AFV: Modern - USA
1/35 LAV-AT and M1128 MGS in progress
twong529
KitMaker: 141 posts
Armorama: 97 posts
Posted: Sunday, February 09, 2020 - 03:05 AM UTC
Here are a couple in progress builds I am doing at the same time.
First up is the Italeri 1/35 LAV-AT. I got the kit second hand and the seller said it was complete but after going over the parts I found that a few parts were missing. Thanks to Ryan (Tank1812) for supplying the missing parts. Also thanks to Rob (18Bravo) for the resin tires. The wire cutters are from the AFV Stryker upgrade set. This will be from OIF 2003 in the NATO camo scheme.
Next up is the AFV 1/35 M1128 Stryker MGS. Thanks again to Rob (18Bravo) for the great Stryker walk around photos to help me along with this build. The DUKE antenna is also from the AFV Stryker upgrade set. I wanted to do one used in Iraq with the slat armor. There are currently no aftermarket slat armor available for the MGS version so unfortunately I will not be adding any and I am not going to attempt to scratch build it, way too complicated for me. It won't be entirely correct but close enough.
Tank1812
KitMaker: 857 posts
Armorama: 703 posts
Posted: Sunday, February 09, 2020 - 03:16 AM UTC
Looking good, glad the parts could help out.
18Bravo
KitMaker: 6,752 posts
Armorama: 5,687 posts
Posted: Monday, February 10, 2020 - 08:27 AM UTC
Same here. Glad those wheels will go to good use finally. Looking good.
Tankrider
Oklahoma, United States
KitMaker: 1,270 posts
Armorama: 1,198 posts
Posted: Monday, February 10, 2020 - 10:42 PM UTC
NIce work so far on the M1128. I did notice that you have the 105D antenna for the DUKE system mounted on the wrong side of the PE mount. The antenna mounts to the opposite of the triangular base.
HTH
John
twong529
KitMaker: 141 posts
Armorama: 97 posts
Posted: Tuesday, February 11, 2020 - 12:54 AM UTC
Thanks again Ryan and Rob.
twong529
KitMaker: 141 posts
Armorama: 97 posts
Posted: Tuesday, February 11, 2020 - 12:59 AM UTC
HTH
John
Thanks John!
The DUKE is only dry fitted for now but it is mounted correctly. On the M1128, the mount is flipped. I cropped these two photos and enlarged the areas and you can just make out the mount.
Tankrider
Posted: Tuesday, February 11, 2020 - 05:21 AM UTC
Well, there seems to be an exception to most things and the M1128 seems to be that exception with the 105D antenna mounts. continue with your work Sir, I will be monitoring your progress...
John
HermannB
Bayern, Germany
KitMaker: 3,894 posts
Armorama: 3,862 posts
Posted: Tuesday, February 11, 2020 - 07:18 AM UTC
LAV-TUA requires a new cupola, kit provided is wrong.
https://www.perfect-scale.de/en/www--perfect-scale-de-3/M901--Hammerhead--Conversion.html
18Bravo
Posted: Tuesday, February 11, 2020 - 07:54 AM UTC
John
My guess is a clearance issue.
