Ships by Class/Type: Military Small Craft
For topics on PT boats, landing craft, Vietnam riverine, etc.
Hosted by Todd Michalak
HMS Sir Gareth, Armed Trawler
RedDuster
KitMaker: 6,658 posts
Armorama: 248 posts
Posted: Monday, September 09, 2019 - 05:03 AM UTC
With limited space, and missing ships, I wanted to find something small and interesting.
I found this.
This kit may be small, but it punches well above it's weight when it comes to detail and complexity.
A closer look.
The hull, not much cleaning up needed.
The resin parts
The etch and some very nice 3d printed resin parts.
There is a turned brass mast and a length of brass rod too.
Work started, the stand built, and the rudder fitted.
The hull has been sprayed Red primer. The rudder assembly is rather fragile so it with has been protected with some foil so I don't rip it off when I mask to spray the upper hull.
I did get a bit further Sunday / Today, but haven't taken the photos off the camera yet.
Si
Black_sheep
Bayern, Germany
KitMaker: 697 posts
Armorama: 139 posts
Posted: Monday, September 09, 2019 - 07:18 AM UTC
Hehe, limited space is a growing menace to the serious modelship builders Simon isn´t it? Sooner or later we have to rething to tackle with 1:2000 scale ships just for the display space
By the way - nice choice you have made. Watching your work at this nutshell with interest.
Thomas
d6mst0
#453
KitMaker: 1,583 posts
Armorama: 578 posts
Posted: Monday, September 09, 2019 - 07:47 AM UTC
Si,
Nice subject you picked. At six inches that is going to one challange you have ahead of you. Looking forward to your progress photos.
Mark
McRunty
#491
Missouri, United States
KitMaker: 394 posts
Armorama: 160 posts
Posted: Monday, September 09, 2019 - 10:18 AM UTC
This looks like a great little project!
SpurnWater71
#504
KitMaker: 76 posts
Posted: Monday, September 09, 2019 - 12:45 PM UTC
Simon,
With your Sir Garth and Starling HMS Algerine and Starling HMS Nadder, we have the makings of diverse little escort group.
RedDuster
Armorama: 248 posts
Posted: Tuesday, September 10, 2019 - 05:45 AM UTC
Thomas
Thanks Thomas,
It is, but that is not my biggest issue quite yet (not far off though), it is not having a functioning workshop, and am reduced to a small table in the corner of the kitchen. (Remodelling part of the house).
Always glad to have you along for the ride.
Si
Always glad to have along Thomas.
RedDuster
Armorama: 248 posts
Posted: Tuesday, September 10, 2019 - 05:50 AM UTC
Si,
Mark
Hi Mark,
Always had an interest in the small workhorses. This is some kit for it's size, it will be a challenge, but then it should be worth it.
Glad to have you aboard.
Si
RedDuster
Armorama: 248 posts
Posted: Tuesday, September 10, 2019 - 05:55 AM UTC
Hi Rory,
It is very nice kit, all I will have to find is the rigging and maybe a couple few figures.
Welcome aboard.
Si
RedDuster
Armorama: 248 posts
Posted: Tuesday, September 10, 2019 - 05:58 AM UTC
Simon,
That it will, pretty typical of RN escort groups, particularly early on in WW2, groups were often thrown together from what was available.
Welcome aboard.
Si
SpurnWater71
#504
KitMaker: 76 posts
Posted: Tuesday, September 10, 2019 - 12:43 PM UTC
Can also add a full division of four Mirage Flower Class corvettes (one of each different kit), a L'Arsenal Hunt class DE, PC, and SC, and a Niko MS.
Quite a large convoy we can escort!
RedDuster
Armorama: 248 posts
Posted: Friday, September 13, 2019 - 06:31 AM UTC
That would be some escort, and don't forget the Trumpy USS England that can be converted into a Captain class Frigate.
Si
RedDuster
Armorama: 248 posts
Posted: Friday, September 13, 2019 - 06:45 AM UTC
Finally found a few minutes to get Sunday / Monday's progress off the camera.
The hull has been sprayed with red primer that looks pretty much like anti fouling red.
The rudder has been protected with a bit of tinfoil, so I don't damage it masking & unmasking.
Masked, the rubbing strakes on the side of the hull were "fun" to mask over.
Sprayed.
The steel area of the decks given a rough coat of dark grey.
The propeller painted & fitted, the boot topping needs a little tidying up, but not too bad.
More soon
Si
d6mst0
#453
Armorama: 578 posts
Posted: Friday, September 13, 2019 - 07:11 AM UTC
Si,
Nice work, but it looks like that boot strap will need some touch up. I am sure it wasn't a joy masking the hull with those bumpers place where they are.
Mark
surfsup
KitMaker: 1,191 posts
Armorama: 2 posts
Posted: Friday, September 13, 2019 - 04:49 PM UTC
That is a nice start on something a little bit different Si.....Cheers mark
RedDuster
Armorama: 248 posts
Posted: Friday, September 13, 2019 - 08:05 PM UTC
Si,
Mark
Thanks Mark,
It was never going to be an easy masking job, the touch up is first on the list.
Si
southpier
KitMaker: 509 posts
Armorama: 303 posts
Posted: Friday, September 13, 2019 - 08:11 PM UTC
Tiny!
RedDuster
Armorama: 248 posts
Posted: Friday, September 13, 2019 - 08:23 PM UTC
Thanks Mark, It is a great kit.
Always liked unusual vessels, especially makeshift escorts. Would love one of these in a larger scale.
Si
RedDuster
Armorama: 248 posts
Posted: Monday, September 16, 2019 - 05:27 AM UTC
Tiny!
It is that, but there is a lot detail, well cast too.
Welcome aboard.
Si
RedDuster
Armorama: 248 posts
Posted: Monday, September 16, 2019 - 05:44 AM UTC
This weekend's progress.
Before starting on the next stage the main superstructure components were cleaned up and test fitted.
some construction.
cable reels.
12pdr gun platform.
forward deck house.
the windlass and cable reels fitted to the fo'c's'le., and some weathering applied.
closer view of the fo'c's'le.
the gun platform painted.
the deck has had a light was & the ready use shells have been picked out in dark green.
The gun platform and forward deckhouse fitted.
Some weathering has been started in the hull, this needs a bit of work yet. these little ships were worked hard, so they would not have been pristine.
Si
d6mst0
#453
Armorama: 578 posts
Posted: Monday, September 16, 2019 - 08:53 AM UTC
Si,
Very nice progress, those cable reels are really tiny. This trawler reminds of the one in my Silent Hunter game.
Mark
GazzaS
#424
KitMaker: 4,290 posts
Armorama: 2,076 posts
Posted: Monday, September 16, 2019 - 10:06 AM UTC
Great project, Si! I've always had an interest in these peacetime vessels impressed into military service. But I think I need them in a larger scale.
I'll enjoy watching you put this one together.
Gaz
SpurnWater71
#504
KitMaker: 76 posts
Posted: Monday, September 16, 2019 - 02:09 PM UTC
Very nicely done Si. Your touch for detail is remarkable.
Kip
RedDuster
Armorama: 248 posts
Posted: Tuesday, September 17, 2019 - 07:48 AM UTC
Si,
Mark
Thanks Mark,
I think they are the smallest reels I have seen since I built 1/700th. The etch is very user friendly, which helped.
Si
RedDuster
Armorama: 248 posts
Posted: Tuesday, September 17, 2019 - 07:59 AM UTC
Gaz
Welcome aboard Gaz,
I agree, they are fascinating. The armed trawlers were hard worked, minesweeping, coastal convoy escorts, and any other job that needed doing.
Would love something like this in 1/72 or even 1/144.
Si
RedDuster
Armorama: 248 posts
Posted: Tuesday, September 17, 2019 - 08:01 AM UTC
Kip
Thanks Kip,
The level of detail on the castings and the etch really help.
This is a very Nice kit.
Si
