Armor/AFV: British Armor
Discuss all types of British Armor of all eras.
Centurion question
Biggles2
Quebec, Canada
KitMaker: 7,143 posts
Armorama: 5,760 posts
Posted: Thursday, May 30, 2019 - 02:38 AM UTC
I just got the 1/72 Ace Models Centurion Mk 5. This kit:
https://www.ebay.co.uk/p/ACE-1-72-Centurion-Mk-5-British-Main-Battle-Tank-72426/1794767045?iid=332639409964
The kit comes with two gun barrels: a 20 lb w/ fume extractor, and another (also 20lb?) without fume extractor. If I use the latter barrel would that make it a Mk 3, or are there other visible differences between the two?
ReluctantRenegade
Wien, Austria
KitMaker: 2,157 posts
Armorama: 2,083 posts
Posted: Thursday, May 30, 2019 - 03:00 AM UTC
Early 20 pdrs came without, later ones with bore-evacuator.
ReluctantRenegade
Wien, Austria
Posted: Thursday, May 30, 2019 - 03:35 AM UTC
The IDF did have Mk.5s equipped with 20 pdrs w/o bore-evacuator:
https://yadlashiryon.com/armored/%D7%98%D7%A0%D7%A7-%D7%A1%D7%A0%D7%98%D7%95%D7%A8%D7%99%D7%95%D7%9F-%D7%A1%D7%99%D7%9E%D7%9F-5-20/
hazzardm
KitMaker: 35 posts
Armorama: 34 posts
Posted: Thursday, May 30, 2019 - 03:46 AM UTC
Some clarifications
The only difference between a Mk3 and a Mk5 is the presence of a ranging co axial MG on the Mk5, that is it, the main armament does not define the variant
The pic of the one at Latrun (above) is an Ex Dutch army vehicle that never entered IDF service.
MJH
ReluctantRenegade
Wien, Austria
Posted: Thursday, May 30, 2019 - 03:55 AM UTC
Good to know, thanks for the clarification! According to the capture, 'large number of Centurion Mk.5s equipped with the 20 pdr gun and Meteor petrol engine were purchased during the second half of the 60s' - so all these had the later type 20 pdr with bore-evacuator?
LeoCmdr
KitMaker: 4,035 posts
Armorama: 3,867 posts
Posted: Thursday, May 30, 2019 - 05:56 AM UTC
The 20 Pounder barrels (A Type- without fume extractor) or (B Type- with fume extractor) were interchangeable with a swap occurring fairly quickly if need be. It would likely depend on what types of barrels were on hand.
A display tank could have simply had a barrel that reached its lifespan mounted as it would never be fired again.
Canadian Centurions Mk. 5s could be seen with A and/or B Type barrels until they were retired in the 1970s...as well as the 105mm L7 for the Mk6 and Mk11LRs.
Gotrek58
Nordrhein-Westfalen, Germany
KitMaker: 663 posts
Armorama: 276 posts
Posted: Thursday, May 30, 2019 - 07:49 AM UTC
...and what about the position of the loaders hatch? IsnĎt that the difference from Mk3 to Mk5?
18Bravo
KitMaker: 6,545 posts
Armorama: 5,514 posts
Posted: Thursday, May 30, 2019 - 07:50 AM UTC
No, it is not.
They began being rotated parallel for mid-production tanks, regardless of mark.
Biggles2
Quebec, Canada
Posted: Thursday, May 30, 2019 - 10:33 AM UTC
So I can build this kit with the non-fume extractor barrel as a Mk 3 in service in Korea - 1951..1952?
LeoCmdr
Posted: Thursday, May 30, 2019 - 12:36 PM UTC
Yes
RLlockie
KitMaker: 968 posts
Armorama: 808 posts
Posted: Friday, May 31, 2019 - 05:49 AM UTC
The loaderís hatch configuration changed to allow the breech ring to be extracted through the roof more easily as I recall.
Other common features which are often claimed to define a 5 against a 3 are the position of the loaderís periscope and the trackguard bin design. Like all tanks with long production runs, these and the change from Type A to Type B 20pdr barrel are just evolutions with no change of designation.
You could turn a Mk 3 into a Mk 5 in a matter of hours by switching the co-ax.
keo
Nordjylland, Denmark
KitMaker: 604 posts
Armorama: 499 posts
Posted: Friday, May 31, 2019 - 06:37 AM UTC
For many years it has been a course of debate here in Denmark weather we received Mkiii or Mk5 Centurion tanks (some even claim we received war beaten samples with holes from the Korean War).
All Iíve seen has the turned turret hatch, the periscope in front of the loader and the side operated boxes on the hull. In the beginning they had Besa guns.
Would it be fair the describe them as late model MkIIIs?
18Bravo
Posted: Friday, May 31, 2019 - 08:19 AM UTC
You have to delete a return roller on each side as well. That was the one other difference between the marks.
ALBOWIE
New South Wales, Australia
KitMaker: 1,544 posts
Armorama: 1,504 posts
Posted: Friday, May 31, 2019 - 02:09 PM UTC
[quote]
The Fender Stowage bins were different and the Loaders hatch position for most Korean war vehicles is in a different position. Some late Mk 3 were almost identical excepting the coax types
18Bravo
Posted: Friday, May 31, 2019 - 03:01 PM UTC
True, for most. But don't let the bins be a show stopper.
RLlockie
KitMaker: 968 posts
Armorama: 808 posts
Posted: Saturday, June 01, 2019 - 05:25 PM UTC
If it has a co-ax Besa, itís a Mk. 3. So yes, you are correct.
