Chipping with Mission paints
PanzerKarl
KitMaker: 2,406 posts
Armorama: 1,950 posts
Posted: Thursday, May 02, 2019 - 06:01 PM UTC
I have read good things about Mission paints but not yet seen or heard how it chips.
Has anyone had ago?
Kaktusas
Vilnius, Lithuania
KitMaker: 196 posts
Armorama: 196 posts
Posted: Thursday, May 02, 2019 - 09:38 PM UTC
I havent gone to extremes of chipping with MM paint yet, but works great for both, painted on chipping and hairspray method.
errains
#045
South Carolina, United States
KitMaker: 328 posts
Armorama: 316 posts
Posted: Thursday, May 02, 2019 - 11:26 PM UTC
Hey Karl the video linked below will totally answer your question and give some great pointers as well.
Michael Rinaldi Hairspray Technique
PanzerKarl
Posted: Friday, May 03, 2019 - 01:34 AM UTC
So it's better than Vallejo as I tried Vallejo years ago and it comes off like rubber clumps.
Eric thanks for the link shall watch that later
errains
#045
KitMaker: 328 posts
Armorama: 316 posts
Posted: Friday, May 03, 2019 - 08:59 AM UTC
I'm not sure if it's mentioned in the video I linked. But Mr. Rinaldi has stated in other videos that MMP can be chipped without the use of hairspray and just water as long as it is done within a day or two after applying the paint. I tried this and it does work as he describes. If you want longer working time over several days/weeks then he advises using hairspray. HTH
ctkwok
Alabama, United States
KitMaker: 191 posts
Armorama: 181 posts
Posted: Friday, May 03, 2019 - 12:20 PM UTC
I think it's a bit nuanced in terms of the type of chippimg you want to achieve with MMP. The paint rubs off with rubbing motion and is great for doing fading effects - Rinaldi did a few of those in his TA books. To do more like the traditional chipping as in pieces coming off, HS is still the better option. Anyway I like MMP primarily due to its chipping properties.
Kaktusas
Vilnius, Lithuania
KitMaker: 196 posts
Armorama: 196 posts
Posted: Sunday, May 05, 2019 - 05:46 PM UTC
Nope, even if im too enthusiastic with washes, i can rub off MM paint with brush to the plastic. If i do the same with Vallejo - its clumps and steps.
You can chip off some top coat and reveal color bellow without hairspray, but i have found i get more control with it. Or, if base coat has been coated with varnish already, its also quite controllable and fun to do.
And yes, time helps a lot as well. The fresher the layer to be chipped - the easier, and the older is the base coat - the better.
