Armor/AFV: Modern Armor
Modern armor in general.
Takom M-47M Iranian Army
dutik
Germany
KitMaker: 134 posts
Armorama: 134 posts
Posted: Monday, February 04, 2019 - 04:22 AM UTC
Searched my modelling magazin stash for articles about using pigments. Found a modeler who simply brushed on pigments diluted with turpentinoid. Tried this and it worked like a charm:
Also reworked the lower hull somewhat:
Now I am working with a dry, stiff brush to reduce the amount of pigments in places and to smooth out everything. Maybe I will add some pigments of different color to the upper hull too. Just to add some variety.
Enjoy!
- dutik
dutik
Germany
KitMaker: 134 posts
Armorama: 134 posts
Posted: Tuesday, February 05, 2019 - 08:36 AM UTC
Reworked the hull bottom with more pigments:
Added black pigments to the painted black exhaust spots:
After scrubbing off some pigments and adding some brighter pigments here and there as well as paintig the bolt heads and all edges with "Iraqi sand" the hull and turret are ready now:
You know that you have done enough wheathering when parts start to break off
Have to repair a few spots where I rubbed off the paint coat or broke off small parts. Next task is the wheatering of the wheels and tracks.
Enjoy!
- dutik
Armorsmith
KitMaker: 1,063 posts
Armorama: 1,000 posts
Posted: Tuesday, February 05, 2019 - 08:45 AM UTC
Shaping up very nicely. Really like the hand applied look of the camouflage.
dutik
Germany
KitMaker: 134 posts
Armorama: 134 posts
Posted: Wednesday, February 20, 2019 - 08:31 AM UTC
Now painting wheels and tracks. Tried some different earthcolored washs, because common track wash is muddy dark brown, not appropriate for a vehicle operating in arid conditions. There is a sand-colored paneel liner from Vallejo that fits the bill.
Guess I will add some pigments at the wheels and tracks too.
Enjoy
- dutik
dutik
Germany
KitMaker: 134 posts
Armorama: 134 posts
Posted: Sunday, February 24, 2019 - 06:59 AM UTC
First track is on:
Really good fit here. Kudos, Takom!
Suggest to drill the holes of the wheels with a 3mm drill to ensure an easy fit and good alignment. Working and painting along the other track now.
BTW, I think my engine deck lovres are way too dark. Any opinions? Should here the base (sand) color more visible? Any M60 experts out there?
Regards
- dutik
dutik
Germany
KitMaker: 134 posts
Armorama: 134 posts
Posted: Sunday, March 10, 2019 - 08:43 AM UTC
I built both of their M-47s. I built the Pakistan version and Iranian version - had issues (my fault) with tracks both times. Pushed them together too much which created a shortened track length. Otherwise - awesome kit! Grabbed another to build another version!
Not your fault. I am also short of one link for the second track. Maybe one and a half. Well, some kind of desaster. Takom should have added two spare links, or made the track building template foolproof.
Solution: I will scratchbuild one link to fill the gap. Maybe some kind of "Franken-link", a bit longer than the original track links.
Stay tuned!
- dutik
dutik
Germany
KitMaker: 134 posts
Armorama: 134 posts
Posted: Thursday, March 14, 2019 - 08:29 AM UTC
Here is the Franke-link:
It is a little bit longer than needed just to be sanded to fit after installation of the remaining track parts. The guide horn is simplified because it is mostly hidden inside a wheel.
Regards
- dutik
dutik
Germany
KitMaker: 134 posts
Armorama: 134 posts
Posted: Sunday, March 17, 2019 - 07:39 AM UTC
Track fixed:
New end connectors are to be added, as well as some paint touch-ups.
Regards
- dutik
dutik
Germany
KitMaker: 134 posts
Armorama: 134 posts
Posted: Sunday, March 24, 2019 - 07:38 AM UTC
The Frankeistein-link completed with end connectors, some boltheads, paint and a wash:
Check the upper right corner.
Last step at the hull is to add the headlight lenses and to peel off the tape from the drivers perioscope. Also adding the clear parts to the turret.
Enjoy
- dutik
