IDF Color for Merkava and Achzarit
igvu333
Luzem, Switzerland
KitMaker: 20 posts
Armorama: 16 posts
Posted: Saturday, January 05, 2019 - 01:42 AM UTC
Hi Folks
During the Xmas holidays I had some time to go on with my IDF projects. The Achzarit from Meng is primered and is waiting for some color. Soon I'll also primer my Merkava I from Tamiya.
From Ammo Mig I have in stash the IDF Sinai Grey 82 (066) color but I'm not sure for which vehicle I should use it. I would like to build the Achzarit from about 1996 and the Merkava from Lebanon 1982 campaing?
Does somebody have a recommendation?
TIA and happy modelling
Igor
GTDeath13
#481
Attica, Greece / Ελλάδα
KitMaker: 799 posts
Armorama: 797 posts
Posted: Saturday, January 05, 2019 - 02:37 AM UTC
You can use the Ammo color for the Merkava and for the Achzarit try adding some dark green(a little darker than nato green would work) to the same paint at about 1/10-1/12 ratio
igvu333
Luzem, Switzerland
KitMaker: 20 posts
Armorama: 16 posts
Posted: Saturday, January 05, 2019 - 08:53 PM UTC
Nikos thanks for the advise.
So the Ammo Mig 066 color fits for Lebanon 1982. Great!
Is there a color from the Ammo or AK range which would fit for the Achzarit?
ReluctantRenegade
Wien, Austria
KitMaker: 1,984 posts
Armorama: 1,958 posts
Posted: Saturday, January 05, 2019 - 09:22 PM UTC
AK has one called ‘IDF Sinay Grey 1990’. Ammo advises its ‘IDF Sinay Grey ‘82’ for the current scheme, which is kind of true, although the color was slightly revised in the early ‘90s.
igvu333
Luzem, Switzerland
KitMaker: 20 posts
Armorama: 16 posts
Posted: Saturday, January 05, 2019 - 10:28 PM UTC
[/quote]
Ammo advises its ‘IDF Sinay Grey ‘82’ for the current scheme, which is kind of true, although the color was slightly revised in the early ‘90s. [/quote]
The Ammo color IDF Sinai Grey 82 (066) I already have in stash. According Nikos (second post) this one fits for the Lebanon 1982 campaign.
Which color would you recommend for then for a Merkava from 1982?
ReluctantRenegade
Wien, Austria
Posted: Saturday, January 05, 2019 - 11:08 PM UTC
Correct, that should match your Mk.1 during the 'Peace for Galilee' campaign. You could use the same color for your '90s Achzarit as well (close enough to the current color), or, because of the minor revision in the early '90s, add a small amount of green to it as Nikos advised.
igvu333
Luzem, Switzerland
KitMaker: 20 posts
Armorama: 16 posts
Posted: Saturday, January 05, 2019 - 11:39 PM UTC
Thank you very much!
Now I know what to do.
ReluctantRenegade
Wien, Austria
Posted: Sunday, January 06, 2019 - 12:06 AM UTC
Some reference here: http://www.armorama.com/modules.php?op=modload&name=SquawkBox&file=index&req=viewtopic&topic_id=260992&ord=&page=7
AgentG
Nevada, United States
KitMaker: 1,069 posts
Armorama: 1,055 posts
Posted: Sunday, January 06, 2019 - 01:02 AM UTC
50/50 mix of Tamiya XF-49 Khaki and XF-20 Medium Gray. Sprayed over a dark gray primer.
G
ReluctantRenegade
Wien, Austria
Posted: Sunday, January 06, 2019 - 01:38 AM UTC
The current IDF color is such an elusive one that I also prefer to mix it from the Tamiya range rather than using ready-made paints.
panamadan
Minnesota, United States
KitMaker: 1,125 posts
Armorama: 1,067 posts
Posted: Sunday, January 06, 2019 - 02:12 AM UTC
Has the IDF ever experimented with camo colors?
Dan
ReluctantRenegade
Wien, Austria
Posted: Sunday, January 06, 2019 - 02:36 AM UTC
Experimental three-tone camo on Mk.2B from 1988-1990.
panamadan
Posted: Sunday, January 06, 2019 - 03:30 AM UTC
Thanks much!
Dan
