true earth weathering -some advice needed
spongya
MODELGEEK
Budapest, Hungary
KitMaker: 2,304 posts
Armorama: 1,656 posts
Posted: Friday, September 28, 2018 - 12:36 AM UTC
I bought a couple of their weathering stuff (aging filters, mostly), which should work simply by adding ont top of the existing paint to darken/lighten the base color.
I suspect due to the fact that they are water based, they do not spread over the surface; even if I mist them with an airbrush, they still pull together in little droplets, unless the surface is extremely flat.
What do people use to break up the surface tension? How do others find them for shading?
Thank you.
Bonaparte84
Hessen, Germany
KitMaker: 324 posts
Armorama: 317 posts
Posted: Friday, September 28, 2018 - 12:49 AM UTC
Don't know about True Earth specifically, but you could try adding a small drop of washing-up liquid from your kitchen. This usually does the trick with water-based stuff...
TopSmith
KitMaker: 1,564 posts
Armorama: 1,489 posts
Posted: Friday, September 28, 2018 - 12:50 AM UTC
Dish soap will break surface tension. Experiment. A drop or two of soap in a 1/4 cup of water and add some of that mix to your acrylic paint. Just a thought.
Bonaparte84
Hessen, Germany
KitMaker: 324 posts
Armorama: 317 posts
Posted: Friday, September 28, 2018 - 12:59 AM UTC
I was faster
brekinapez
Georgia, United States
KitMaker: 2,075 posts
Armorama: 1,725 posts
Posted: Friday, September 28, 2018 - 01:36 AM UTC
Yes, but Greg was a bit more detailed.
spongya
MODELGEEK
Budapest, Hungary
Posted: Friday, September 28, 2018 - 01:38 AM UTC
Thank you for both?
varanusk
Staff MemberManaging Editor
Santa Cruz de Tenerife, Spain / Espaņa
KitMaker: 1,121 posts
Armorama: 809 posts
Posted: Friday, September 28, 2018 - 04:15 AM UTC
guess that your base is gloss... lay a coat of flat varnish and it should work better. Same for applying pigments.
165thspc
#0
Kentucky, United States
KitMaker: 9,132 posts
Armorama: 8,377 posts
Posted: Friday, September 28, 2018 - 04:31 AM UTC
Yes, lay a base coat of matte clear to give some "tooth" to the surface plus a drop of dish washing liquid to the shader to break up the surface tension. This will much reduce the tendency for the water based paints and/or shaders to clump up.
If you are near a store that caters to professional photographers you might inquire as to a photo processing product called "Photo-Flo". This stuff has been around for about 100 years, it's cheap, and it's sole purpose is to break up the surface tension of the water in the photo processing chemicals. This so the glossy photo prints do not spot as they air dry.
The Photo-Flo has the advantage of not adding any "suds" to the paint which just might cause other unwanted problems.
Vicious
KitMaker: 1,453 posts
Armorama: 1,067 posts
Posted: Friday, September 28, 2018 - 10:31 AM UTC
on their site you will find many videos and info on how to use their products and the owner is also active here from time to time with his models with the nickname "Ironwork" if I remember correctly...however, with certain products they recommend to slightly wet the surface before application
It is he who you must contact....
https://www.armorama.com/modules.php?op=modload&name=SquawkBox&file=index&req=viewtopic&topic_id=269951&page=1
spongya
MODELGEEK
Budapest, Hungary
Posted: Sunday, September 30, 2018 - 08:37 PM UTC
Wetting the surface is actually a really good idea. Thank you. Will try.
Vicious
Posted: Sunday, September 30, 2018 - 09:00 PM UTC
if you subscribe to their newsletter they always send you links to their tutorials that are many and well done
