Circumcised Sherman
ReluctantRenegade
Wien, Austria
KitMaker: 2,097 posts
Armorama: 2,046 posts
Posted: Sunday, September 16, 2018 - 05:11 AM UTC
One of the major drawbacks of the Sherman was its high silhouette. The IDF tried to cure the problem by cutting some 30cm off of the upper part of the hull. Only one example was ever built.
https://bukvoed.livejournal.com/
jps
Wisconsin, United States
KitMaker: 112 posts
Armorama: 106 posts
Posted: Sunday, September 16, 2018 - 05:16 AM UTC
Interesting but 30 cm is a awlful lot for a circumcism.
Was the conversion done by a welder or Rabbi?
I gotta million of "em. Some may even be funny.
Dave
RobinNilsson
Staff MemberTOS Moderator
KITMAKER NETWORK
Stockholm, Sweden
KitMaker: 5,001 posts
Armorama: 4,223 posts
Posted: Sunday, September 16, 2018 - 09:02 PM UTC
Dave
A mohel, מוֹהֵל, probably trained in oxy-acetylene cutting ...
/ Robin
Joke below, nothing offensive but IF you are the slightest sensitive you may want to stop reading right now.
Here goes:
So there’s an old joke about a guy who’s looking to get his watch fixed. He passes a little shop with clocks and watches in the window, and goes inside.
“Can I help you?” asks the man behind the counter.
“I want this watch repaired,” says the first guy.
“I’m sorry. I don’t repair watches.”
“Well, how much for a new one then?”
“I don’t sell watches.”
“You don’t sell watches?”
“No, I don’t sell watches.”
“Clocks, you sell clocks then? How much for a clock?”
“I don’t sell clocks.”
“You don’t sell watches, you don’t sell clocks?”
“No, I’m a mohel,” replies the man behind the counter. “I perform circumcisions.”
“Then why do you have all those clocks and watches in the window?”
“If you were a mohel, tell me, what would you put in your window?”
ReluctantRenegade
Wien, Austria
Posted: Sunday, September 16, 2018 - 09:30 PM UTC
mogdude
KitMaker: 413 posts
Armorama: 179 posts
Posted: Monday, September 17, 2018 - 01:17 AM UTC
So what was reduced the turret ring area ? looks like the engine deck may still be original height any other photos of this available ?
RobinNilsson
KITMAKER NETWORK
Stockholm, Sweden
Posted: Monday, September 17, 2018 - 01:28 AM UTC
Compare these two images:
Regular Easy-8 Sherman
IDF cut down version (Da Lowrider)
Use the diameter of a roadwheel to compare the height of the side of the hull nex to the turret
The angle of the side going up from the rear end to the turret is also different. The engine deck has been made less steep so that it can meet the rear edge of the top plate (the hole for the turret).
/ Robin
ReluctantRenegade
Wien, Austria
Posted: Monday, September 17, 2018 - 01:57 AM UTC
The main contributor to the Sherman's rather high profile was the fact that the hull had to accommodate the R975 radial engine the vehicle was initially designed with. The Cummins diesel engines fitted to IDF M50s had a much lower shaft allowing to lower the engine deck.
pod3105
Waterford, Ireland
KitMaker: 354 posts
Armorama: 342 posts
Posted: Monday, September 17, 2018 - 01:58 AM UTC
/ Robin
Here goes:
“I want this watch repaired,” says the first guy...
Almost a coffeesnot moment there...
Scarred
KitMaker: 1,095 posts
Armorama: 755 posts
Posted: Monday, September 17, 2018 - 02:24 AM UTC
That hurts just thinking about it.
rfbaer
KitMaker: 1,726 posts
Armorama: 1,573 posts
Posted: Monday, September 17, 2018 - 04:08 AM UTC
Best read I've had all day!
So, that's what the hot rodders call "sectioning", and it looks good, like it might make a nice project in 1/35.
Cantstopbuyingkits
European Union
KitMaker: 2,083 posts
Armorama: 1,906 posts
Posted: Monday, September 17, 2018 - 05:05 AM UTC
Trying to reduce the Sherman's height without wanting to drop the front trans and crankshaft was never going to work.
RobinNilsson
KITMAKER NETWORK
Stockholm, Sweden
Posted: Monday, September 17, 2018 - 05:24 AM UTC
New engine with a lower position of the outgoing axle allows a more horizontal drive shaft. The transmission looks to be low enough already.
/ Robin
Edit: I hope I found a better cross section
Full resolution: https://ww2db.com/images/vehicle_sherman27.jpg
Silantra
Putrajaya, Malaysia
KitMaker: 2,510 posts
Armorama: 913 posts
Posted: Monday, September 17, 2018 - 05:38 AM UTC
Dave
/ Robin
Here goes:
i still dont get it...what do mohel put in their window??
RobinNilsson
KITMAKER NETWORK
Stockholm, Sweden
Posted: Monday, September 17, 2018 - 06:20 AM UTC
Dave
/ Robin
Here goes:
How would You illustrate the mohels profession knowing that he performs circumcisions? So this mohel chose to display watches and clocks instead of .......
/ Robin
jps
KitMaker: 112 posts
Armorama: 106 posts
Posted: Monday, September 17, 2018 - 07:04 AM UTC
While I originally made light ot the 30 cm comment it does interest me to know what version of the Sherman this is based on. I assume this was a M50 but could this have originally be a M4A3E8. Yes It would be an interesting build.
Dave
barkingdigger
KitMaker: 3,427 posts
Armorama: 2,924 posts
Posted: Monday, September 17, 2018 - 07:44 AM UTC
Looks like they sacrificed the underfloor ammo stowage, but it certainly made for a mean-looking ride! Any hope of overhead pics?
Loved the joke BTW
Cantstopbuyingkits
European Union
Posted: Wednesday, September 19, 2018 - 09:12 PM UTC
/ Robin
True, but that would require the reversal of underfloor ammo stowage, the most effective method for stopping the burning inconvenience.
ReluctantRenegade
Wien, Austria
Posted: Wednesday, September 19, 2018 - 09:52 PM UTC
Judging by the photos, this vehicle had to undergo major changes in the crew- and powertrain-departments.
RobinNilsson
KITMAKER NETWORK
Stockholm, Sweden
Posted: Wednesday, September 19, 2018 - 10:17 PM UTC
I found this. I don't know anything about the image, except what is written on it, whatever it may be worth ...
/ Robin
barkingdigger
Posted: Thursday, September 20, 2018 - 05:35 AM UTC
Excellent find, Robin! I assume that's the Cummins diesel engine at the back? There's a gear tower at the output end to drop the prop shaft to the floor, and for want of underfloor ammo bins it looks like they crammed shells in everywhere they could regardless of brew-up risk. But by this time the Sherman's armour wasn't thick enough to keep enemy shells out anyway, so it couldn't really increase the already-high risk I guess! After all, by then the tank was just a gun-carrier given the big guns the Arab nations were using.
Looks like another potential kitbash...
Das_Abteilung
KitMaker: 365 posts
Armorama: 351 posts
Posted: Thursday, September 20, 2018 - 08:19 AM UTC
Once the GM6046 and Ford GAA engines began to be used it was realised in the US that a lower-profile M4 was a practical proposition. But it was turned down because - among other reasons such as the prospect of the T-23 - it would have caused far too much production disruption to make the changes across 10 assembly plants and hundreds of sub-suppliers. I'm not sure it was ever prototyped: Hunnicutt doesn't show it IIRC.
A low-hull M4 with the GAA/GAF, M26 turret and the M26-style torsion-bar suspension trialled on an M4A2 would have been a huge improvement and might have changed the landscape of post-war tanks. Diesel power was not realistic at the time as the Navy needed all the diesel they could get their hands on. Same in the UK and Germany, less so in Russia. That situation persisted into the 1960s.
I've already got about a dozen IDF M4 projects lined up. But I think I've just found another one.......
Cantstopbuyingkits
European Union
Posted: Thursday, September 20, 2018 - 11:09 AM UTC
/ Robin
That breach looks way too small for a above medium velocity 90mm.
Chillidragon
KitMaker: 90 posts
Armorama: 60 posts
Posted: Thursday, September 20, 2018 - 09:15 PM UTC
The version of the Mohel story I heard had a barber's pole, with the "customer" breezing in and asking for "a bit of a trim"...
Still, the Rabbi gets the fees, but the Mohel keeps the tips!
Looking at the drawing of the 90mm Sherman, I wonder if the cut down IDF vehicle was actually the American prototype, bearing in mind how a prototype upgraded Centurion ended up in an export batch (and which the IDF are said to have had no idea what to do with).
ReluctantRenegade
Wien, Austria
Posted: Thursday, September 20, 2018 - 10:59 PM UTC
I don't think so. Assuming the drawing depicts the actual prototype, the suspension is different from that on the photos. Besides, based on the info in the link, the conversion was (most likely) done in one of IDF's major repair facilities in Tel HaShomer near Tel-Aviv.
RobinNilsson
KITMAKER NETWORK
Stockholm, Sweden
Posted: Thursday, September 20, 2018 - 11:25 PM UTC
Oh f-word, I didn't get that one until the second time I read it ....
