Making Tamiya XF-86 Flat clear flatter
rowdycat
Ohio, United States
KitMaker: 97 posts
Armorama: 82 posts
Posted: Thursday, August 30, 2018 - 09:25 AM UTC
Tamiyas XF-86 Flat Clear is not flat enough. Tamiya makes X-21 flat base that can be added to paints to make them duller.
If I added X-21 flat base to XF-86 flat clear, would it make XF-86 flatter?
Thanks Jim
SgtRam
Staff MemberEditor-in-Chief
AEROSCALE
#197
KitMaker: 3,916 posts
Armorama: 2,848 posts
Posted: Thursday, August 30, 2018 - 09:46 AM UTC
I am not sure if that will resolve the issue. I had the same issue, so I have switched to Model Master Clear Flat, and it works great.
Vicious
KitMaker: 1,336 posts
Armorama: 982 posts
Posted: Thursday, August 30, 2018 - 10:19 AM UTC
if the experiment XF-86 + X-21 does not work and you want the flattest varnish of all the flat go with AK-183 Ultra Matte Varnish, it's Dead Matt, for me it's the best I've tried
mudcake
South Australia, Australia
KitMaker: 50 posts
Armorama: 47 posts
Posted: Thursday, August 30, 2018 - 10:28 AM UTC
Are you using a paint brush or air brush?
sgtreef
Oklahoma, United States
KitMaker: 6,017 posts
Armorama: 4,341 posts
Posted: Thursday, August 30, 2018 - 12:08 PM UTC
Not acrylic, but old stand by Dullcoat is very flat.
Namabiiru
#399
Rhode Island, United States
KitMaker: 2,717 posts
Armorama: 1,822 posts
Posted: Thursday, August 30, 2018 - 12:29 PM UTC
You can make any Tamiya color dead flat by using alcohol as your thinner. Something about the formulation of Tamiya paints alcohol has that effect on them.
johhar
Alabama, United States
KitMaker: 449 posts
Armorama: 420 posts
Posted: Thursday, August 30, 2018 - 01:16 PM UTC
Is that isopropyl alcohol?
GulfWarrior
KitMaker: 473 posts
Armorama: 470 posts
Posted: Thursday, August 30, 2018 - 01:26 PM UTC
I've been wanting to try the AK ultra matt. SprueBrothers is out of stock right now. I'm hoping to find some at my club's contest next weekend.
sdk10159
Oregon, United States
KitMaker: 552 posts
Armorama: 430 posts
Posted: Thursday, August 30, 2018 - 08:03 PM UTC
What I use is:
Task a couple tablespoons worth of Modelmaster Acryl Flat Clear and mix with a couple drops of Tamiya Flat Base. Then I thin with 91% Rubbing Alcohol.
Flattest I've ever seen. Be careful though. Too much flat base and the result will be as if you sprayed wet talcum powder on your model.
Steve
Kaktusas
Vilnius, Lithuania
KitMaker: 196 posts
Armorama: 196 posts
Posted: Thursday, August 30, 2018 - 08:48 PM UTC
Same here. All my "not matt enough" problems have disappeared with AK-183 Ultra Matte Varnish.
rdt1953
KitMaker: 982 posts
Armorama: 66 posts
Posted: Thursday, August 30, 2018 - 10:15 PM UTC
The AK UltraMatte is easy to use and indeed dead flat - at first .
Every thing I have used it on has turned slightly glossy after a year or so - this is after using it over Vallejo model air colors . Anyone else experience this ?
Namabiiru
#399
Posted: Thursday, August 30, 2018 - 11:24 PM UTC
Yes
rowdycat
Ohio, United States
KitMaker: 97 posts
Armorama: 82 posts
Posted: Sunday, September 02, 2018 - 03:16 AM UTC
Thanks everyone for your help. I think I'll try the AK stuff.
Rowdycat
