Black Plague Zelda instructions/parts
HermannB
Bayern, Germany
KitMaker: 3,637 posts
Armorama: 3,609 posts
Posted: Saturday, August 04, 2018 - 03:19 PM UTC
Found on 1999.co.jp the parts and instructions for Dragon M113 Zelda.
https://www.1999.co.jp/eng/10533634
Like noticed by some here before, this model is pretty simple and the forgotten fuel filler cab is a big let down. Doesn`t look better than the old crappy Italeri release.
GTDeath13
Attica, Greece / Ελλάδα
KitMaker: 806 posts
Armorama: 804 posts
Posted: Saturday, August 04, 2018 - 05:57 PM UTC
Thank you for sharing. I have to say it looks interesting, I will wait for the reviews.
system
KitMaker: 353 posts
Armorama: 352 posts
Posted: Saturday, August 04, 2018 - 09:17 PM UTC
When did the IDF change the bench seating to run down the middle rather then the sides of the rear compartment? Was that a pre-73 or post-73 mod?
KitMaker: 17,034 posts
Armorama: 13,234 posts
Posted: Sunday, August 05, 2018 - 12:41 AM UTC
It doesn't look horrible. The fuel filler cap is on the sprues in one of the blued-out areas of unused parts. Look on sprue B below the roof hatch. Based on the other unused parts, more versions are likely planned.
m4sherman
Arizona, United States
KitMaker: 1,779 posts
Armorama: 1,730 posts
Posted: Sunday, August 05, 2018 - 03:22 AM UTC
It looks like they used the old Tamiya and Academy as inspiration. Step 1 has you cutting part of the side plate or plates off, and removing the grease caps off the wheels.
Didn't the last versions of the M113 have external fuel tanks only, or did they keep the inside tank?
The model has potential, but it looks like Dragon stopped a little short. I'll bite the bullet and go for the AFV kit for the Zelda I have in mind.
Posted: Sunday, August 05, 2018 - 11:03 AM UTC
The external fuel tanks were available with the A2 model, but not added to US M113s until the A3 upgrade. IDF M113s started having the tanks added to A2 models. Also, when the external tanks are added, the internal tank is removed.
m4sherman
Posted: Sunday, August 05, 2018 - 01:55 PM UTC
Thank you. Perhaps Dragon used a later M113 as a base and simply forgot to add the fuel cap to the instructions. After working on a few Dragon T-34's I find that a trademark. The bench seats on the sides, instead of down the center, is a little harder to understand.
jasegreene
KitMaker: 712 posts
Armorama: 712 posts
Posted: Sunday, August 05, 2018 - 04:31 PM UTC
I have to agree,I too will be waiting for the reviews on this before rushing to buy it.Until then I might check out the new AFV Club version.
