Armor/AFV: Modern - USA
Bronco T-142 does not fit M60 from AFV Club
GTDeath13
Attica, Greece / Ελλάδα
KitMaker: 921 posts
Armorama: 919 posts
Posted: Saturday, April 21, 2018 - 01:43 AM UTC
??? If the M60 sprocket is smaller than the M88 sprocket with the same number of teeth, they must be different pitches (which is correct) and the company did not cheat and use a single pitch for both vehicles (which is wrong).
KL
I will try to rewrite my previous awful post
AFV Club m88 sprocket is larger in diameter by their m60a1 sprocket by o.5mm = 0.0196".
The Slingshot sprocket is the same diameter with the AFV club m60a1 sprocket.
The AFV Club m88 sprocket has longer teeth compared to the Slingshot sprocket.
The diameter of the sprocket where the track sits on both the m88 sprockets and the m60a1 kit sprocket is the same which means that all three sprockets have the same pitch.
Did I explain it better now?
