current paint scheme used on Israeli armor
tanknick22
KitMaker: 1,044 posts
Armorama: 1,007 posts
Posted: Friday, February 02, 2018 - 01:12 AM UTC
Im wondering what is the current color used on all Israeli armored vehicles
Do they still use the sand gray as in the color from model master?
I read some where they are reverting to a shade of olive drab
Any assistance will be appreciated
MarshGelbart
KitMaker: 11 posts
Armorama: 11 posts
Posted: Friday, February 02, 2018 - 01:06 PM UTC
Over several decades photographing IDF armour, I have noticed a shift from what is generally thought of as Sinai Grey, to a drab olive with a greyish tinge.
You also need to take account that digital cameras will give different results according to light conditions, so that the same colour appears to have different tones and accents.
Because the initial paint coating applied to Merkavas includes basalt chips, the paint is readily coated with dust from local terrain. Thus tanks with an identical colour paint finish, can look very different when seen in the Negev when compared to the Golan.
In addition I do believe when IDF tanks are given a paint refresh, units do marginally change the exact tone and tinge of the paint used, to reflect local conditions.
Marsh
AgentG
Nevada, United States
KitMaker: 1,073 posts
Armorama: 1,059 posts
Posted: Friday, February 02, 2018 - 01:29 PM UTC
I sprayed my Achzarit with a 50/50 mix of Tamiya Khaki, XF-49 and Medium Gray, XF-20.over a dark gray primer (Krylon rattle can). I used Deck Tan, XF-55 to lighten it for modulation.
No pics tonight I'm at work.
G
tanknick22
Posted: Friday, February 02, 2018 - 04:57 PM UTC
Marsh
So that being said you could see a Merkava IV in a shade of olive drab or kahki?
GTDeath13
#481
Attica, Greece / Ελλάδα
KitMaker: 799 posts
Armorama: 797 posts
Posted: Friday, February 02, 2018 - 05:06 PM UTC
Chose your color ...
GTDeath13
#481
KitMaker: 799 posts
Armorama: 797 posts
Posted: Friday, February 02, 2018 - 05:17 PM UTC
some other vehicles with variations:
tanknick22
Posted: Friday, February 02, 2018 - 05:52 PM UTC
those pics were a great help thank you im going to use my Merkava I as a test subject and use krylon's olive as a primer base then a light coat of thier kahki as the base coat
GTDeath13
#481
KitMaker: 799 posts
Armorama: 797 posts
Posted: Friday, February 02, 2018 - 05:57 PM UTC
Take in mind that the weathering might really affect your color shades.
For instance at this photo the two vehicles are painted with the same color but with different weathering:
the front one has no dust on it and the rear one had also a grey filter before weathering.
18Bravo
KitMaker: 6,403 posts
Armorama: 5,385 posts
Posted: Friday, February 02, 2018 - 07:11 PM UTC
For a more dramatic example of the differing colors, refer to the IDF graveyard thread from several weeks ago. You can see several different shades all within the same photo.
cabasner
KitMaker: 930 posts
Armorama: 883 posts
Posted: Friday, February 02, 2018 - 08:44 PM UTC
To reiterate/repeat much of what has already been posted here, and an extract from a thread from several years ago: I happen to be a big fan of Tamiya acrylics, (limited though my experience may be), and I personally am not thrilled with the complications involved in enamel painting (smell, clean-up, etc.), so I was very interested in determining if there was an acrylic equivalent to Humbrol 84 (which has been THE current IDF color, per Michael Mass, an IDF expert), preferably in Tamiya colors. There are a number of suggestions for mixes of colors for current IDF vehicles that can be found here on Armorama, but I verified an almost perfect match to Humbrol 84 this morning. It is: 2 parts XF-20 Medium Grey to 1 part XF-49 Khaki. Perhaps an even closer match may be a 1.5 to 1 ratio, which would result in just the smallest adjustment to the green end of the scale, but I have not yet tried that. As is, the 2:1 ratio is just fine!
Though this was from several years ago, I stand by the 2:1 Tamiya XF-20 to XF-49. And, as many have written, dust/dirt which is so prevalent in Israel, changes to overall color quite a bit.
ReluctantRenegade
Wien, Austria
KitMaker: 2,023 posts
Armorama: 1,997 posts
Posted: Friday, February 02, 2018 - 09:18 PM UTC
AFAIK the standard IDF color hasn't changed in the past 30-35 years.
GTDeath13
#481
KitMaker: 799 posts
Armorama: 797 posts
Posted: Friday, February 02, 2018 - 09:32 PM UTC
There is a slight variation in tone at the beginning of the 90's but nothing major.
ReluctantRenegade
Wien, Austria
Posted: Friday, February 02, 2018 - 09:40 PM UTC
Frankly, I find that hard to believe. The IDF moves its hardware around the country quiet frequently, it wouldn't make any sense to adjust to local conditions.
When I was a greenhorn, I asked once why we don't have those cool camouflage uniforms other armies have. They made me roll over in the dust and told me 'there you go'. The same rule applies for AFVs as well: after no time in the field they'll be covered by dust/sand anyway. Between us, who cares about the exact color in such conditions...?
AgentG
Posted: Friday, February 02, 2018 - 11:16 PM UTC
Here are photos of my Achzarit painted with the 50/50 Tamiya mix of Khaki and Medium Gray.
G
MarshGelbart
KitMaker: 11 posts
Armorama: 11 posts
Posted: Saturday, February 03, 2018 - 09:59 PM UTC
Hi Nick,
Not Khaki. Olive drab with a faint grey tinge to it.Then add local dust to the mix!
Marsh
exgrunt
Massachusetts, United States
KitMaker: 261 posts
Armorama: 261 posts
Posted: Sunday, February 04, 2018 - 12:21 AM UTC
Word. Most folks who have been in the field will confirm that after a very short time, everything, including troops are covered with a uniform layer of dirt / mud / dust. Seems crazy that the IDF would go to the trouble of repainting their armor using a very slightly different shade every time a unit relocated to a different part of the country.
jps
Wisconsin, United States
KitMaker: 110 posts
Armorama: 104 posts
Posted: Sunday, February 04, 2018 - 01:39 AM UTC
Israel,
Love that photo of the dusty Merkava 4. I think I have to do my Meng Merkava 4 (when I get it) like this. What part of Israel has this redish brownish dust. Is this from the Golan? I also note that the crew is in matching camo uniforms.
By the way thank you for all the photos you have put up on IDF armor.
Dave
ReluctantRenegade
Wien, Austria
Posted: Sunday, February 04, 2018 - 02:17 AM UTC
Some parts of the Northern Negev have this kind of red soil, so I would say the photo was taken somewhere around the the Gaza Strip, but I'm not entirely sure...
Thanks! Hang around, as more to come...
ReluctantRenegade
Wien, Austria
Posted: Thursday, February 08, 2018 - 06:47 PM UTC
Note how a layer of dust accumulated on the horizontal surfaces changes the appearance of the tank...
ReluctantRenegade
Wien, Austria
Posted: Thursday, February 08, 2018 - 07:17 PM UTC
A Namer perfectly 'adjusted' to local conditions
