World War II: Germany
Aircraft of Germany in WWII.
Hosted by Rowan Baylis
Revell 1/48 JU88A-4 Question?
stevedb227
Missouri, United States
KitMaker: 53 posts
Armorama: 38 posts
Posted: Monday, July 31, 2017 - 02:03 AM UTC
Greetings!
Just bought the Revell 1/48 JU88A-4 and I have a spare set of Eduard cockpit photoetch and Masks for a Dragon JU88A-6. Should I buy a new set for this kit or would the A-6 stuff work for the A-4. Any info would be appreciated.
Emeritus
Uusimaa, Finland
KitMaker: 2,845 posts
Armorama: 808 posts
Posted: Monday, July 31, 2017 - 03:13 AM UTC
Which Revell Ju88A-4 did you get? The newer ICM reboxing or one of their earlier Dragon reboxings?
If it's the Dragon reboxing, the aftermarket stuff you have should fit in just fine as it's essentially the same plastic. If it's the newer ICM kit, you can probably make use of most - if not nearly all - of the PE set (some trimming might be required here and there, though), whereas the shapes of the canopy parts might differ enough between the kits to justify getting a new mask set specifically made for it.
stevedb227
KitMaker: 53 posts
Armorama: 38 posts
Posted: Monday, July 31, 2017 - 04:33 AM UTC
Many thanks for your advice. Yes its the newer ICM version. I was thinking the same about the photoetch cockpit but you are probably right, the mask I will buy a new one. No sense going cheap on such a nice kit.
