Hosted by Richard S.
Campaign 500+ Mk. II
d111298pw
#456
Delhi, India / भारत
KitMaker: 646 posts
Armorama: 630 posts
Posted: Monday, October 30, 2017 - 08:26 PM UTC
Mark,
Those kits are on my wish list as well.
More progress this evening. Completed the first step with the aft panel of the chassis, and started on the road wheels.
The instructions do not call out parts D5 & D6, even though they are included on the sprue, and the mounting holes on part W20.
Parts lay-out. Another 20 just for this step.
Assembled.
Attached to the chassis
On to the road wheels. This is for one side, 40 pieces. 80 for the vehicle. One big issue is that the axle diameter is 2.35mm. The road wheel hub diameter is 2.80mm. That's a gap of .45mm . Needless to say, the wheel is very loose on the axle. Will have to figure out a solution to get a proper fit. I'll get all of this painted first before installing at the end of the build.
d6mst0
#453
KitMaker: 1,653 posts
Armorama: 588 posts
Posted: Tuesday, October 31, 2017 - 05:31 AM UTC
Mark,
Missing parts in a Dragon instructions, why am I not surprised.
That is quite a gap on those wheels. Its the first I heard such a thing about Dragon.
A lot of parts to make those road wheels but they will look good. The rubber tires being separate will sure make it easier to paint them.
Mark
d111298pw
#456
Delhi, India / भारत
KitMaker: 646 posts
Armorama: 630 posts
Posted: Wednesday, November 01, 2017 - 09:35 PM UTC
Just a little bit more progress
d6mst0
#453
Armorama: 588 posts
Posted: Thursday, November 02, 2017 - 04:48 AM UTC
Nice work on the M.G..
petbat
KitMaker: 2,770 posts
Armorama: 2,596 posts
Posted: Thursday, November 02, 2017 - 02:14 PM UTC
Sorry, Mark. Had a bad storm here Sunday and lightning frazzled my network adapter and a few appliances around the house. Came through the Ethernet connections. Only just replaced the part.
Yep, it is a chore and yes I did warn you it was not a quick build with lots of test fitting and putty, but it looks like you have tamed the beast.
You seem to like adding detail, so I'm not sure if you want to fill the big rectangular hole in the ammo container or not - the wall is actually supposed to be flush completely across. The recess is actually just a gap where the block of wood is moulded on the outside.
Also, where the grab handle bolts, crane rest, etc, are on the outside of the ammo container, there is a little rectangular plate with a nut on the inside. Also all the rivets for the cross bracing are on the inside too (but even I wan't that crazy)
Ohh... and don't look too closely at the grapple..... or the cut outs around the rear circumference on the ammo round....
Have fun with the seam lines around the ammo retaining straps.
petbat
Posted: Thursday, November 02, 2017 - 02:18 PM UTC
and your 4 is coming along nicely too... err, Mark #2
This is gonna get confusing
https://www.youtube.com/watch?v=bNBy1D1Y0h4
petbat
Posted: Friday, November 03, 2017 - 02:59 AM UTC
Just to show I haven't been idle. Started on the 'Grasshopper".
The running gear is not the multipart components you get with some of Dragon's other Panzer IV's:
Haven't decided whether to use the early drive sprocket or go for the later one. Pics show both used at times. Also in this pic is the start on the AFV Club ammo set I am using as well.
The hull under way. Tip for anyone building this kit, the shell racks with the holes are not perfectly rectangular, so make sure you put them in the right way. There are two more doors to fit to each bin here. I'm thinking of adding figures. I haven't decided on a reloading scene or action scene yet. The cartridge racks have no doors, and I can't find any references to say if they had a canvas cover like some other vehicles...might just add them anyway, to cover the fact both racks have the same missing cartridge cases
One big draw back on this kit, like the Trumpeter one, is no driver's compartment. Anyone wanting to display the gun turret dismounted is going to have a glaring void. Once the turret is done, I will see how much is visible with it in place. I may have to scratch build some of the compartment.... and work out which bits were Panzer 3 and which Panzer IV. If Dragons drive train position is correct, they must have had the same Panzer 3 transmission as the Hummel
The wheels for the gun frame when the turret is dismounted. Dry fit to hull. A lot of time spent on removing mould seams here, and I missed the one on the aerial mount. That is the best thing about taking pics.. you see your mistakes.
There is a panel to add underneath too
.. and I found out why they are called Magic Tracks - when ready to be built, they magically jump onto the kit without any instructions from Dragon on how to assemble them
RobinNilsson
Staff MemberTOS Moderator
KITMAKER NETWORK
Stockholm, Sweden
KitMaker: 5,925 posts
Armorama: 4,965 posts
Posted: Friday, November 03, 2017 - 03:40 AM UTC
https://www.youtube.com/watch?v=0p_1QSUsbsM
petbat
Posted: Friday, November 03, 2017 - 05:02 AM UTC
I appreciate your taste in music. You could have opted for:
https://www.youtube.com/watch?v=MzlK0OGpIRs
And to think when Freddie and the boys played at the Sunbury Music Festival here in Australia in 1974, they were not well received....
d6mst0
#453
Armorama: 588 posts
Posted: Friday, November 03, 2017 - 06:44 AM UTC
That Grasshopper is coming along nicely. I have this kit so your build will be most interesting.
Armored76
Bayern, Germany
KitMaker: 1,615 posts
Armorama: 1,500 posts
Posted: Friday, November 03, 2017 - 05:10 PM UTC
Nice progress everyone! I should probably make up my mind about the kit I'm going to build... Maybe the Trumpeter A-222 Bereg? According to the box, it has 1000+ parts.
petbat
Posted: Saturday, November 04, 2017 - 09:23 AM UTC
You have my vote on that one. I'd love to see that being built.
Armored76
Bayern, Germany
Posted: Saturday, November 04, 2017 - 06:40 PM UTC
Thanks Peter! It's just a matter of finding the required time
d111298pw
#456
Delhi, India / भारत
KitMaker: 646 posts
Armorama: 630 posts
Posted: Sunday, November 05, 2017 - 08:57 PM UTC
Was able to make a little more progress. The basic upper hull is now complete.
Dry fitting of the add-on armor
d6mst0
#453
Armorama: 588 posts
Posted: Sunday, November 05, 2017 - 09:04 PM UTC
That extra armor looks sweet.
petbat
Posted: Monday, November 06, 2017 - 01:22 PM UTC
Bling, Bling. You don't miss the etch do you!
Keep up the great work Mark
d111298pw
#456
Delhi, India / भारत
KitMaker: 646 posts
Armorama: 630 posts
Posted: Monday, November 06, 2017 - 07:41 PM UTC
I'm not a big fan of little pe parts. My fingers are too big.
It's not pretty, but it's assembled. Works for me.
d6mst0
#453
Armorama: 588 posts
Posted: Monday, November 06, 2017 - 10:44 PM UTC
Works for me also.
petbat
Posted: Tuesday, November 07, 2017 - 04:21 PM UTC
I hear you on the itty bitty etch. You did a great job on getting the curves on the retaining clip Mark.
ClaytonFromEllijay
#454
Georgia, United States
KitMaker: 1,273 posts
Armorama: 1,138 posts
Posted: Wednesday, November 08, 2017 - 12:31 AM UTC
Big fingers isn't my problem with tiny etch- it's the miniscule amount of patience I have for it!
d111298pw
#456
Delhi, India / भारत
KitMaker: 646 posts
Armorama: 630 posts
Posted: Wednesday, November 08, 2017 - 10:44 AM UTC
Thanks. That really tried my patience. Can't wait to get to the pe latches for the tooling.
d111298pw
#456
Delhi, India / भारत
KitMaker: 646 posts
Armorama: 630 posts
Posted: Wednesday, November 08, 2017 - 07:49 PM UTC
The hull is mated with the chassis. All the tools will be painted separately and installed last.
The main gun is assembled. Of course, none of it will be visible so I won't bother painting the interior.
Next is the turret.
d6mst0
#453
Armorama: 588 posts
Posted: Wednesday, November 08, 2017 - 08:18 PM UTC
Making nice progress.
Charlie-66
#186
KitMaker: 762 posts
Armorama: 743 posts
Posted: Wednesday, November 08, 2017 - 09:28 PM UTC
Here is my entry to the campaign. I plan on building the version with the short 50mm gun, added armor on turret and hull front.
MichaelSatin
AEROSCALE
KitMaker: 3,639 posts
Armorama: 499 posts
Posted: Thursday, November 09, 2017 - 01:34 AM UTC
Hmmm...
I was thinking about this one but upon reading the rules it looks like only creepy-crawlies allowed, no wingey-thingeys. Shame...
Michael
