No balls and chains on early Merkava I's?
jps
Wisconsin, United States
KitMaker: 147 posts
Armorama: 140 posts
Posted: Friday, December 08, 2017 - 06:41 PM UTC
Assembly of my Mk 1 is nearing completion. I am using the Echelon sheet.
I will have no ball and chain and no antislip. Photos of the Merk I am doing show no track links on the base of the turret and do not appear to show the personal weapon storage on the turret. I will be using 2 antennas and will have to sculpt a camo cover for the turret basket storage.
cabasner
Nevada, United States
KitMaker: 1,083 posts
Armorama: 1,014 posts
Posted: Friday, December 08, 2017 - 07:03 PM UTC
...and will have to sculpt a camo cover for the turret basket storage.
If you haven't used Kneadatite yet, in my humble opinion, this is THE best stuff to use for things like covers or rolled up/folded tarps, etc. As long as you use baking soda and water to keep the stickiness under control, you can roll this stuff out to paper thinness (or less) and use it for things like covers on the sides of over the top of IDF turret baskets, and when cured a bit, you can easily cut straps out of it. Just a thought
By the way, which Merkava I are you building? Do you have a photo (or several) that you are using?
1721Lancers
KitMaker: 1,673 posts
Armorama: 1,640 posts
Posted: Sunday, May 13, 2018 - 10:45 PM UTC
Hi there fellow modelers, I have another question for the Merkava Mk1 (early) without AS and ball and chain.
Did the first Merkava batch have a thermal cover on the 105mm, or is it
possible that some were without this feature?
Thanks for any help and please don't start fighting about the possible incoming answers.
GTDeath13
Attica, Greece / Ελλάδα
KitMaker: 921 posts
Armorama: 919 posts
Posted: Sunday, May 13, 2018 - 11:39 PM UTC
It is highly unlikely that there were operational vehicles without the thermal sleeve.
The thermal sleeve is even seen on prototype or test vehicles.
ReluctantRenegade
Wien, Austria
KitMaker: 2,408 posts
Armorama: 2,300 posts
Posted: Monday, May 14, 2018 - 12:00 AM UTC
All operational Merkava 1s were equipped with thermal sleeves. This is the very first example:
If you fancy to build one sans, you’ve gotta throw an M48 turret on it I'm afraid...
1721Lancers
Posted: Monday, May 14, 2018 - 11:09 PM UTC
Nikos, Israel many thanks fellas
