Legend's OWS
corsutton
Oklahoma, United States
KitMaker: 540 posts
Armorama: 507 posts
Posted: Friday, December 30, 2016 - 02:23 AM UTC
OK, so I am curious about this system.
Mainly, since there is an ammo box hanging on the side, and the belt feed is shown looping over the box, where is the feed drawing ammo from? Is there another ammo box inside the sight housing? Is the feed looping through the sight housing into the body the system is mounted on?
knewton
New Zealand
KitMaker: 927 posts
Armorama: 843 posts
Posted: Friday, December 30, 2016 - 02:32 AM UTC
Yes;on the real vehicle, the belt feeds from inside the hull; the box would not be there.
corsutton
KitMaker: 540 posts
Armorama: 507 posts
Posted: Friday, December 30, 2016 - 07:24 AM UTC
Great, thank you. Is the ammo can inside the hull mounted to the same rotating piece the gun is mounted on, so the belt not tangled?
KitMaker: 16,760 posts
Armorama: 13,019 posts
Posted: Friday, December 30, 2016 - 07:30 AM UTC
What vehicle is this system used on?
knewton
New Zealand
KitMaker: 927 posts
Armorama: 843 posts
Posted: Friday, December 30, 2016 - 08:15 AM UTC
That would be the Puma and Achzarit. I've not seen it on any other vehicles, IDF or otherwise.
Of note, there is a newer OWS with a 50cal being rolled out to the Achzarit fleet, the Drakonit. Hopefully that is not far away in scale form!
happy new year and all that,
K.
knewton
New Zealand
KitMaker: 927 posts
Armorama: 843 posts
Posted: Friday, December 30, 2016 - 08:18 AM UTC
Yes, the ammo can is affixed to the left of the unit below the roof line. Thereby allowing the additional of further belts to the machine gun from the safety of the hull. As seen here,
http://www.armorama.com/modules.php?op=modload&name=SquawkBox&file=index&req=viewtopic&topic_id=37872&page=1
K.
corsutton
KitMaker: 540 posts
Armorama: 507 posts
Posted: Friday, December 30, 2016 - 09:10 AM UTC
HeavyArty, here it is on top of a Puma I believe
corsutton
KitMaker: 540 posts
Armorama: 507 posts
Posted: Friday, December 30, 2016 - 09:12 AM UTC
Not sure why these pics are all showing so small, sorry for that.
Posted: Friday, December 30, 2016 - 09:29 PM UTC
Thanks for the vehicle. Looks like this is used on multiple IDF vehicles.
To get the pics to show larger, delete the thumbs/ portion in the image code: ht tp://gal lery3.kitmaker.net/data/500/thumbs/ aaaaa10.jpg
once deleted, you get this...
junglejim
KitMaker: 1,700 posts
Armorama: 1,602 posts
Posted: Saturday, December 31, 2016 - 02:34 AM UTC
Going through some photos, it seems when used on the Puma the box is mounted more often than not, while on the Achzarit it is a plain belt or feed chute, no box mounted.
Puma:
Jim
