Modeling Questions?
How to make a block of water
masonre
Cape Province, South Africa
KitMaker: 23 posts
Armorama: 20 posts
Posted: Tuesday, November 01, 2016 - 02:41 PM UTC
Hi there
I want to make an underwater diorama, but do not want to use a glass/plastic/acrylic tank.
I'd also prefer not to use resin because of the customary air bubbles that one gets by using resin.
I want to build the block by layering clear varnish until the required height. I realise that this will take weeks, if not months.
What I do not know is how to layer the varnish within a cube so that it does not stick to the cube. What material does varnish not stick to? Or what release agent can I apply that the varnish will not stick to?
Any ideas please?
Thanks
Richard
see the following pic for what I mean by "block of water"
KitMaker: 17,044 posts
Armorama: 13,243 posts
Posted: Wednesday, November 02, 2016 - 06:22 PM UTC
Varnish isn't going to cut it. You have to use clear acrylic or epoxy water. This is the stuff florists and the like use for making artificial arrangements with "water" in them. Not sure what you would make the cube with, but I'm sure you could research it more. Start here, this thread has some good tips.
masonre
KitMaker: 23 posts
Armorama: 20 posts
Posted: Thursday, November 03, 2016 - 11:16 AM UTC
Thanks Gino. It's a start....
justsendit
KitMaker: 2,845 posts
Armorama: 2,309 posts
Posted: Thursday, November 03, 2016 - 11:46 PM UTC
Hi Richard,
Check this out ... 'A Dragon Wagon Odyssey.' Not a cube but it might be worth a read anyway (about halfway down page 6). Jason Lehrer gives a fairly detailed account of how things can go badly when adding a styrene model to the mix, he also explains what ultimately worked for his really cool diorama. HTH.
ómike
jimb
KitMaker: 2,224 posts
Armorama: 238 posts
Posted: Saturday, November 12, 2016 - 07:43 PM UTC
Here's another thread that has a block of water: TBM Avenger. Might be useful.
Jim
masonre
KitMaker: 23 posts
Armorama: 20 posts
Posted: Tuesday, November 15, 2016 - 01:22 PM UTC
thanks guys
