World War II: Germany
Aircraft of Germany in WWII.
Hosted by Rowan Baylis
1/48 Bf 109E-7/Trop (Eduard)
Venko555
Bulgaria
KitMaker: 907 posts
Armorama: 697 posts
Posted: Thursday, October 27, 2016 - 01:02 PM UTC
Well, I'm having mood for Bf 109's, so starting this very good model from Eduard-the Weekend edition. I have to wait new decals for the Zvezda bf 109F-2, in the meantime will build this plane.
The marking I choose is the Werner Schroer bird, the famous "Black Eight". It's one of the two markings provided in the kit, so quality decals expected here .
Not very much AM will be used, only RB metal barrels for MG 17 and wings mounted FF. The main shortcoming of the kit is the absence of the radiators and tropical filter meshes, I will have to scratch them.
Cheers!
KelticKnot
Scotland, United Kingdom
KitMaker: 768 posts
Armorama: 12 posts
Posted: Thursday, October 27, 2016 - 03:47 PM UTC
I like the finish on the "Black Eight". I'm looking forward to seeing how your model turns out.
Venko555
Bulgaria
KitMaker: 907 posts
Armorama: 697 posts
Posted: Thursday, October 27, 2016 - 04:00 PM UTC
Thanks!
The tropical filter is not available on the market as separate replacement, so I will have to scratch that mesh and the other ones for the coolers:
lespauljames
KitMaker: 3,661 posts
Armorama: 2,764 posts
Posted: Thursday, October 27, 2016 - 06:24 PM UTC
this is one of my favorite 109's im looking forward to this,having messed up two doing the same scheme.
Venko555
Bulgaria
KitMaker: 907 posts
Armorama: 697 posts
Posted: Thursday, October 27, 2016 - 07:47 PM UTC
From what I have understood, this Weekend kit is retool of the older Profipack version, correcting some shape issues, and the detail is very, very good
Regards!
Venko555
Bulgaria
KitMaker: 907 posts
Armorama: 697 posts
Posted: Friday, October 28, 2016 - 05:54 PM UTC
For the radiator's grills I decided to use filter for coffee machine . This is the finest mesh which I found. Even on the real plane it's a very small grill, scaling to 1/48 makes it finer. I like the result, then drybrushing with Stainless metalizer. I don't know if it's brass, as instruction says, on pictures is steel
Venko555
Bulgaria
KitMaker: 907 posts
Armorama: 697 posts
Posted: Saturday, October 29, 2016 - 11:53 AM UTC
I decided to put metal barrels only for the FF cannons on the wings, the MG's on the nose are OK. PVC supports for extra strength.
alpha_tango
Germany
KitMaker: 5,609 posts
Armorama: 264 posts
Posted: Saturday, October 29, 2016 - 03:09 PM UTC
Regards!
that is wrong. Weekend editions are just the plastic of the standard kit. BTW check the length of the Sandabscheider. IMHO it it too long...
all the best
Steffen
Venko555
Bulgaria
KitMaker: 907 posts
Armorama: 697 posts
Posted: Saturday, October 29, 2016 - 03:46 PM UTC
Hi, Stephen
I mean retool for this particular Bf 109E-7, not all Eduard kits
Sandabscheider-if this means the tropical filter, yes it's a bit long
Proceeding with the cockpit. Basic detailing, I had leftover seat belts from Eduard PE set, so decided to put them instead the Superfabric ones.
RLM 02 is Gunze, drybrushing with Stainless Metal color.
Cheers!
alpha_tango
Germany
Armorama: 264 posts
Posted: Saturday, October 29, 2016 - 04:06 PM UTC
Hi Venelin,
nice progress!!
Eduard did retool the canopy when the kit first came out as good old Standa Archmann (who was also in charge for the first Bf 109G-6 edition "hickup" 2014) made the E-4 canopy too small in width assuming the rear section would still be the same.
But believe me the Weekenders are only Profipacks without 4 decals options, masks, and PE...
all the best
Steffen
P.S. built that PP kit some years ago Bf 109E-7 trop of Günther Steinhausen
kahunaminor
New South Wales, Australia
KitMaker: 151 posts
Armorama: 10 posts
Posted: Sunday, October 30, 2016 - 01:34 AM UTC
Hi Venelin,
Nice progress on the E-7. As you note, Eduard has the filter sections on part 2 of their PE for the E-7, which is a bit mean. They also do not include Part 2 in their PE for either the Weekend or stand alone E4/E7 frets. I think that is a bit rough but I don't make the parts. Maybe somebody out there has an unwanted piece they could send you? The coffee filter is a good idea. How much are you going to trim off the trop filter? I ask as I am building an E-7 at the moment as well.
Venko555
Bulgaria
KitMaker: 907 posts
Armorama: 697 posts
Posted: Sunday, October 30, 2016 - 09:06 AM UTC
Eduard only offers a small PE fret (FE703), which I don't like and doesn't include many necessary details as the grills and is rather expensive for such small set. Set 8264 is discontinued and includes many more parts (you can see on their site) and was cheaper. Very strange decision from their part, I think
The tropical filter will be cut with about 2mm, but you have to align it to the middle recessed panel line on the cowl for more precise measurement. The coffee filter is very good for the grills and will do the same as with the radiator grills.
Cheers!
Venko555
Bulgaria
KitMaker: 907 posts
Armorama: 697 posts
Posted: Sunday, October 30, 2016 - 01:36 PM UTC
Also, I ordered Quickboost gunsights Revi 12 (48007), the one from the kit is molded as clear part and although convincing i think the resin gunsight will be better.
Antilles
Nordrhein-Westfalen, Germany
KitMaker: 648 posts
Armorama: 40 posts
Posted: Monday, October 31, 2016 - 01:49 AM UTC
Hello Venelin,
the black eight really has a nice camo and Your Messerschmitt built gets along very nice? I will follow with interest as I have the 1/72 Tamiya one in my stash.
Oliver
Venko555
Bulgaria
KitMaker: 907 posts
Armorama: 697 posts
Posted: Monday, October 31, 2016 - 05:21 PM UTC
New instrument panel, cut from plastic sheet and with the decals, I like it more now. Also dark wash and oils on the cockpit.
Cheers!
lespauljames
Posted: Monday, October 31, 2016 - 05:59 PM UTC
Really nice work. What oils do you use ?
Venko555
Bulgaria
KitMaker: 907 posts
Armorama: 697 posts
Posted: Monday, October 31, 2016 - 06:07 PM UTC
Thanks,
buff, light green, yellow and blue. I have selection of Daler Rowney and several 502 Abteilung oils
Venko555
Bulgaria
KitMaker: 907 posts
Armorama: 697 posts
Posted: Tuesday, November 01, 2016 - 11:20 AM UTC
Dry fit, testing the alignment of the new instrument panel. I like how it turned out. Some levers left to put, before closing the cockpit.
Scrodes
KitMaker: 771 posts
Armorama: 1 posts
Posted: Tuesday, November 01, 2016 - 09:36 PM UTC
You might want to consider toning down the white on those dials a bit. A coat of Tamiya Smoke is what I would use. Alternatively mix up a batch of clear flat, add a single drop of light grey paint.
Venko555
Bulgaria
KitMaker: 907 posts
Armorama: 697 posts
Posted: Tuesday, November 01, 2016 - 10:14 PM UTC
Thank you for the advice,
Venelin
Venko555
Bulgaria
KitMaker: 907 posts
Armorama: 697 posts
Posted: Wednesday, November 02, 2016 - 02:27 PM UTC
Several levers on the instrument panel added and toning it down a bit.
The engine have to be cut in the front, so the cowl can be closed without problems. Also most of the details will be left over.
Venko555
Bulgaria
KitMaker: 907 posts
Armorama: 697 posts
Posted: Wednesday, November 02, 2016 - 10:07 PM UTC
Forgot to mention that I've made from the same mesh those pads (or whatever is the name), I suppose it's an anti-slip or something
Venelin
BlackWidow
European Union
KitMaker: 1,582 posts
Armorama: 242 posts
Posted: Thursday, November 03, 2016 - 12:02 AM UTC
Hi Venelin,
nice progress on you Emil. I'm curious, do the Eduard folks provide stencils with this weekend kit? I have the E-1 Weekend here with no stencils at all. When I wrote to Eduard they told me that this is correct. So I have to use the remnants of my G-6 Profi Pack stencils ....
Torsten
Venko555
Bulgaria
KitMaker: 907 posts
Armorama: 697 posts
Posted: Thursday, November 03, 2016 - 12:25 AM UTC
Some of the new Weekenders have the stencils. Including this one
Cheers!
Venko555
Bulgaria
KitMaker: 907 posts
Armorama: 697 posts
Posted: Friday, November 04, 2016 - 12:38 AM UTC
I accidently broke the tail wheel, but you have to install it before closing the fuselage. So I drilled two holes respectively and put a piece of plastic rod in the wheel.
Fitting as a whole is almost perfect, the only place which needs a filling is under the engine.
