General Ship Modeling: Painting & Color Schemes
Topics on painting and paint schemes are grouped here
aerosol can primer
doppelganger
Idaho, United States
KitMaker: 557 posts
Armorama: 217 posts
Posted: Sunday, October 16, 2016 - 09:05 PM UTC
My next build will be the HMS Warspite 1:350 scale. I am not sure if I want to start this build during the cold season. This model is enormous I never worked on such a large model. I have a paint booth in my hobby room however the hull takes up about 80% of the width.I do not think I can get a consistent layer of paint on the hull considering I have limited mobility. I am thinking of trying a rattle can primer out in the garage if the temp is above 60? problem is I think rattle cans suck. the paint just shoots out of the can with little flow control leaving an uneven coat of paint and easily starts to run or orange peel.How do you guys use a rattle can? I read about many people doing so but what are typically the results. I insist on using lacquer paint since I feel it is less damage prone.My airbrushes are questionable for painting large surfaces? not sure. I have an Iwata HP-M1 top feed Revolution with a small1.5 ml cup and a Iwata Eclipse HP-BCS that will accept large bottles. What do you think?
timmyp
KitMaker: 424 posts
Posted: Monday, October 17, 2016 - 03:42 AM UTC
Well, I used a rattle can primer on a 1/35th scale tank. I don't have any kind of spray booth, and the tank itself is fairly small (a German Panzer II), so my biggest problem was overspray. Plus, I think the can said to "hold upright" - which is silly, considering the parts are flat on the desktop! But it seemed to do ok, and the more I think about it, the more I think that spray can was pretty old (like, bought in the nineties), and used up maybe 2006? Besides, it was an all-purpose primer from K-mart, nothing especially formulated for styrene.
GrantGoodale
KitMaker: 99 posts
Posted: Monday, October 17, 2016 - 04:03 AM UTC
I think that there are a few key points when using rattle cans. Keep the spray moving! Pausing leaves big amounts of dripping paint on your model. Also, use several light misting coats rather than a few heavy coats.
HTH
Tojo72
KitMaker: 4,577 posts
Armorama: 3,426 posts
Posted: Monday, October 17, 2016 - 04:28 AM UTC
I use Tamiya Fine Primer on my armor,no problem,light coats,keep it moving,have not had runs,drips or orange peel,just takes practice.
B_Ernie
#266
KitMaker: 50 posts
Armorama: 20 posts
Posted: Monday, October 17, 2016 - 06:39 PM UTC
I used Mr Surfacer 1200 from a rattle can on the hull of my Revell 1/144 USS Fletcher (it's a work in progress that is almost finished) and it went on with no problems, many light coats, as stated above, is the key to a smooth finish.
Here is a sneak preview,
doppelganger
KitMaker: 557 posts
Armorama: 217 posts
Posted: Monday, October 17, 2016 - 08:19 PM UTC
I will try the Tamiya or Mr. surfacer, seems like a bit more control on those cans. Thanks to all for the tips
doppelganger
KitMaker: 557 posts
Armorama: 217 posts
Posted: Wednesday, October 19, 2016 - 04:11 PM UTC
did you carve out each of those hull plates? if so...wow, that is a lot of work and very impressive. I remember how that looked on the USN ship I served on.Huzzah!
