Hosted by Richard S.
Landships Campaign
Hudson29
#460
KitMaker: 1,156 posts
Armorama: 1,024 posts
Posted: Tuesday, January 17, 2017 - 12:22 AM UTC
Paul, if you look closely you'll see that the reel is empty. I had no idea what to put on it (and Hobby Boss doesn't address it in the instructions; further, the reel that I ultimately used was from an older Eduard PE set that didn't specify what it was for, either) and can only speculate. I believe that it was mentioned elsewhere in this thread that it was a winch, presumably for hoisting supplies aboard. Somewhere down the line I'll see what I can find for period references for hoist cables and hooks/grapples; I'll add something then, I guess!
I may post a Q over on the Russian forum to see if anyone there can fill in the details on this reel. There are also some mysterious cylindrical objects on the sides of the main turret superstructure that someone may be able to illuminate . . .
Hudson29
#460
Posted: Tuesday, January 17, 2017 - 12:28 AM UTC
Alex - Wow, your T-28 is certainly complicated! I see a number of similarities with the T-35. The cooling fan & shroud look the same and the T-35 suspension is als covered by the outer plates. The suspension is very different. I believe the turrets were also common between the two?
Hudson29
#460
Posted: Tuesday, January 17, 2017 - 12:33 AM UTC
Xavier - Your Char is certainly coming along, very impressive! I'm sorry to hear the tracks are fragile. I had a set of Modelkasten tracks I built for a T-34/85 that broke so many times while trying to assemble them that I gave up and built a set of Fruils that were just a joy to work with. Are metal tracks available for the Char? I know my fat fingers & thumbs value sturdyness .. .
hofpig
KitMaker: 1,330 posts
Armorama: 1,017 posts
Posted: Thursday, January 19, 2017 - 07:42 PM UTC
Ok after my last attempt to up load the pics (the rubbish ones off my tablet) here are some fresh ones along with a bit of progress...(2nd attempt damn you photobucket and my lousy internet connection!!).
Nice and bright pic!
Ok so some extras for the top... Commercial POW containers(panzerart) pretty sure both the markings and type of cans were around in 1920, Oil container(ultracast) no idea if these are suitable but I think will be ok, a couple of tarps(resicast) might put these on the rear stowage rack and a bucket(or two( Tamiya)).
Cobblestone base for the beast to sit on.
Some friendlies for the base if I have time...
So here are all the wheels and axles nice and cleaned up(only took 2 weeks) so that's the boring bit out of the way onto something fun. At least the tracks look nice and easy with no clean up required!
Hudson29
#460
Posted: Thursday, January 19, 2017 - 10:00 PM UTC
Great start Paul! I like your organization with all of those wheels & axles in separate pockets. I'm looking forward to seeing your model with the figures and top hamper installed on the base. The perfect example of a real life landship.
hofpig
Posted: Friday, January 20, 2017 - 07:03 PM UTC
Hi Paul,
Your right organisation is pretty key on this part, So many wheels and axles to keep track of....Speaking of which they are all glued now so heres a couple of pics.....But I noticed a couple still need a bit of clean up!
Now I can start on the rest of the pieces that make up the rest of the track gears....
Scipio2010
#401
KitMaker: 323 posts
Armorama: 221 posts
Posted: Thursday, January 26, 2017 - 07:42 AM UTC
I put the finishing touches on the 1/144 Takom Landkreuzer last night. This was my first attempt at building an AFV in a different scale than 1/35, and it was definitely a challenge when it came time for painting and weathering. I kept the paint job on the Landkreuzer simple - I figured such a large object would be easily spotted regardless of the camo pattern.
The two Maus (Mice?) that come with the kit were fun to paint.
I kept the weathering to a minimum on all three AFV's. I feel like at 1/144 scale you probably wont be seeing many of the details im used to adding to my builds (mud splatters, paint shipping, etc)
Overall, pretty interesting build, but I think Ill stick to my 1/35 AFV's. I included an unfinished 1/35 Maus in one of the pictures to provide some scaling comparisons.
ClaytonFromEllijay
#454
Georgia, United States
KitMaker: 1,273 posts
Armorama: 1,138 posts
Posted: Thursday, January 26, 2017 - 08:23 PM UTC
It's a cool addition to anyone's shelf, I'll wager...
Savage
KitMaker: 1,405 posts
Armorama: 656 posts
Posted: Friday, January 27, 2017 - 11:00 PM UTC
Got my 1/72 Tadpole for this build
Hudson29
#460
Posted: Wednesday, February 01, 2017 - 12:10 AM UTC
Shawn - What a great Landship! That thing is amazing. The railing & ladders look like PE and just right for the scale.
Don't forget to post a couple of pics in the gallery if you haven't already done so.
Hudson29
#460
Posted: Wednesday, February 01, 2017 - 12:14 AM UTC
Eric - Your Tadpole looks like fun. I had some of the Emhar 1/35 kits in the past but never knew they did 1/72 version.
Hudson29
#460
Posted: Wednesday, February 01, 2017 - 12:25 AM UTC
I have been away from modeling for a week or so with out of town guests and a new reloading press to play with. I did get a bit more done on the Zvezda T-35 kit. The bogie assemblies are done and are trial fitted to the hull. I'll glue them on after painting. Here are some pics:
Hudson29
#460
Posted: Tuesday, February 07, 2017 - 10:05 PM UTC
Has anyone been working on their Landships?
I have been spending my modeling time on a Dragon Jagdpanther for the Big Cat campaign which is on short deadline. This last week has been spent trying to make the ATAK zimmerit kit to fit the model, what a mess! I look forward to getting back to the more straightforward T-35 . . .
Shalta
Guangxi, China / 简体
KitMaker: 165 posts
Armorama: 160 posts
Posted: Monday, February 13, 2017 - 10:36 AM UTC
I'm due to start on mine within the month, or at worst, next month. I've got a few simple builds to help me adjust to modelling again, and then I'll HOPEFULLY be ready to start on my M60A1, The PE still looks pretty intimidating, but I'm looking forward to it.
I've been feeling better since around Christmas, numerous things happened since then (Nothing bad, luckily), but it's been nice watching progress on the builds in this campaign! It's been helping me get the motivation to build again, and if nothing else, I feel pretty lucky to still have the option to!
Sorry if this post is a little off-topic, I'm still just in a pretty happy mood that I recovered 100%
Shalta
Guangxi, China / 简体
KitMaker: 165 posts
Armorama: 160 posts
Posted: Monday, February 13, 2017 - 10:42 AM UTC
Though, I admit to being a little hesitant to build that M60A1 so soon. What does everyone think on the validity of the Type 5 Chi-Ri as a "landship"? I've had my eye on the FM kit of it for a while, and the size / hull mounted secondary gun look very "landship" to me!
https://en.m.wikipedia.org/wiki/Type_5_Chi-Ri
Link for those that arent familiar! (It's 2 AM, just grabbed Wikipedia, lol)
Bravo1102
KitMaker: 2,864 posts
Armorama: 2,497 posts
Posted: Monday, February 13, 2017 - 11:35 AM UTC
I would think so. It's in the same class as the Char bis and M6 heavy tank.
I'm finishing the weathering on my Crusader. I got stuck on Pzkpfw I link to link track on my build for improvised ingenuity.
Shalta
Guangxi, China / 简体
KitMaker: 165 posts
Armorama: 160 posts
Posted: Monday, February 13, 2017 - 07:00 PM UTC
That's what I assumed. Thanks
I'm just limited by how long it takes for the order to arrive, as getting FM kits locally seems like a no-go.
Hudson29
#460
Posted: Monday, February 13, 2017 - 10:05 PM UTC
I'm with Stephan, it sure looks like a Landship to me. WW2 Japanese subjects are a special interest of mine and I would doubly welcome seeing a Chi-Ri built here. Please feel free to build away.
Hudson29
#460
Posted: Monday, February 13, 2017 - 10:09 PM UTC
We have plenty of time on this campaign due to the complicated nature of some of the Landship models. The deadline isn't until September so build away as time permits. My own T-35 is on hold while I try to finish the Jagdpanther.
ClaytonFromEllijay
#454
Posted: Tuesday, February 14, 2017 - 01:25 AM UTC
Yeah, it'll be a couple more months before I get into my T-28, only have, what, 14 other campaigns this spring/summer
Hudson29
#460
Posted: Tuesday, February 14, 2017 - 02:29 AM UTC
You are a busy man! I completed 11 models last year, a record for me but 14 is better than one per month, a real achievement.
Shalta
Guangxi, China / 简体
KitMaker: 165 posts
Armorama: 160 posts
Posted: Tuesday, February 14, 2017 - 03:32 AM UTC
Ok, perfect. As I've been planning to buy that kit since I started modelling. Having an excuse to only makes it better!
... I might also get a 1/72 O-I with it, if shipping allows.
Hudson29
#460
Posted: Tuesday, February 28, 2017 - 02:51 AM UTC
Is anybody working on a Landship lately? It has been pretty quiet around here . . .
My own T35 project is on hold for another week or two while I finish the Jagdpanther for the Big Kitty campaign. The T35 is still right there on the bench and it has not been forgotten!
ClaytonFromEllijay
#454
Posted: Tuesday, February 28, 2017 - 04:39 AM UTC
LOL, I have to schedule builds for all my campaigns,and my Landship is still 5 away, but some of those will be quick ones...so many is a good problem to have!!!
Hudson29
#460
Posted: Tuesday, February 28, 2017 - 04:45 AM UTC
I hear ya! We gotta lotta time with this campaign so of course, it will get put off until the eleventh hour. That's human nature!
The good part for me is that that darned T35 is so fascinating that I want to get to it sooner rather than later . . .
