Armor/AFV: Modern - USA
M1151A1 w/B1+SPARK+CROWS II, Aca/Leg/Bro
youngtiger1
KitMaker: 534 posts
Armorama: 344 posts
Posted: Friday, August 19, 2016 - 11:46 AM UTC
Man, my internet was down for two days and it drove me nuts as I couldn't check out all of the cool stuff here. Now, that's bad... but it's good to be back online and see all this cool stuff.
Anyway, thanks for the link on the nuts and bolts. I like it as they are plastic and like Eric, I too prefer using plastic cement over super glue. So, thank you for the info...again
Eric, I did find your build and man you are doing some cool work as well. I'm following that along as well
kubisz
Wojewodztwo Slaskie, Poland
KitMaker: 978 posts
Armorama: 977 posts
Posted: Friday, August 19, 2016 - 01:48 PM UTC
Dennis, Thanks for Your feedback I'm sure this break in modelling was very good for me, maybe it's not the same feeling which I had before it, but I've got quite fun building this model.
Small update - additional elements of Frag Kir armor:
M4A1Sherman
KitMaker: 4,403 posts
Armorama: 4,078 posts
Posted: Friday, August 19, 2016 - 04:04 PM UTC
Dennis, the MENG bolts are amazing. My favorite attribute is that they are made from styrene. I don't like resin because I don't like using cyanoacrylate glues. They. Also come in a wide variety of shapes and sizes. You get a ton of each size too. There are two issues I have with the MENG bolts. One, they don't come small enough. .8mm is a pretty large in 1/35th. Two, the detail is a bit soft in the smaller sizes. I've used a ton of them on my current HMMWV chassis. I wish they would do .6 mm, .5mm and .4mm. That would make life easier.
Eric
Hi, Eric!
THANKS MUCH for your feedback on the MENG Bolts-
Try GRANDT LINE for the smaller Nut and Bolt sizes. GRANDT LINE mainly caters to the Model Railroad Crowd, of which I am also part of, (I like to scratch-build HO Scale "prototype" Steam Power out of brass and plastic), but their Nut and Bolt sets are easily adaptable to other scales...
kubisz
KitMaker: 978 posts
Armorama: 977 posts
Posted: Monday, August 22, 2016 - 10:52 PM UTC
Underbody armor, dryfitted:
rogerjo1
Västra Götaland, Sweden
KitMaker: 950 posts
Armorama: 905 posts
Posted: Monday, August 22, 2016 - 11:49 PM UTC
Very nice Humvee Kuba, looking forward to see it painted
kubisz
KitMaker: 978 posts
Armorama: 977 posts
Posted: Tuesday, August 23, 2016 - 10:29 PM UTC
Roger, thanks a lot. But You have to wait, there's a long way to painting...
Underbody armor after some corrections. Also small PE elements added at the corners of lower part of the body:
After glueing to the body these gaps visible at the front at the first photo will disappear.
kubisz
KitMaker: 978 posts
Armorama: 977 posts
Posted: Wednesday, August 24, 2016 - 08:12 PM UTC
Armor plates behind rear seats:
Yes, there is a sunny weather today in Poland
youngtiger1
KitMaker: 534 posts
Armorama: 344 posts
Posted: Sunday, August 28, 2016 - 10:12 AM UTC
Coming along real nice buddy. btw, what are you using for reference for interior armor?
kubisz
KitMaker: 978 posts
Armorama: 977 posts
Posted: Sunday, August 28, 2016 - 10:43 AM UTC
Thanks, Mike
For reference I've used these photos (and drawing, but it's for different version):
http://g503.com/forums/viewtopic.php?f=64&t=273441
Manual HMMWV TM 9-2320-387-24P
And then I've made this:
kubisz
KitMaker: 978 posts
Armorama: 977 posts
Posted: Sunday, August 28, 2016 - 07:38 PM UTC
Armor plate improved:
The beginning of SPARK:
All is mounted movable, so it will be corrected after build finished.
kubisz
KitMaker: 978 posts
Armorama: 977 posts
Posted: Monday, August 29, 2016 - 10:57 AM UTC
Mine roller going on:
It's a little bigger than I thought, so there will be not much free space on the vignette. With all I want to put there it will be looking more or less like this:
kubisz
KitMaker: 978 posts
Armorama: 977 posts
Posted: Monday, August 29, 2016 - 05:37 PM UTC
SPARK finished:
Only wiring left to make, it will be glued after painting, as well as wheels.
youngtiger1
KitMaker: 534 posts
Armorama: 344 posts
Posted: Tuesday, August 30, 2016 - 12:17 PM UTC
Kuba, thanks for the info on armor plates buddy. It sure will make things easy The spark is looking nice, is it by Legend or Blast?
The_musings_of_NBNoG
Oregon, United States
KitMaker: 520 posts
Armorama: 516 posts
Posted: Tuesday, August 30, 2016 - 12:39 PM UTC
Very clean work on the Spark...which Legend # is this one..?
I also spy a few add on bits to it...
what did you add and why...? (please)
I'm contemplating a M1128 w Slat and Spark.. Found a only a few photos of this combo... Aaaahhh but what a build.
WXerock
#450
KitMaker: 672 posts
Armorama: 668 posts
Posted: Tuesday, August 30, 2016 - 01:13 PM UTC
The_musings_of_NBNoG, looking at photos I am sure this is the Legend Spark system they make for the HMMWV. The Blast Spark has squared resin flaps over the wheels while the Legend one has curved photo etched flaps. Legend does make one with the squared off flaps, but those are for MRAPs, not HMMWV's. I hope this helps!
Eric
kubisz
KitMaker: 978 posts
Armorama: 977 posts
Posted: Tuesday, August 30, 2016 - 05:53 PM UTC
Thanks, Gents
Yes, this is a Legend's SPARK (in the first post in this thread there is a list of all sets with catalogue numbers). I added only a Rhino mounting.
Legend makes three different sets of roller - for Humvee with curved flaps, also for RG-31 and M923 with squared flaps. All has mostly the same elements beside these flaps and mountings to the vehicle - all vehicle has different front sections, so the mountings are different too.
Mentioned mounting for Rhino (made of PE brass) is included only in a set for M923.
kubisz
KitMaker: 978 posts
Armorama: 977 posts
Posted: Wednesday, August 31, 2016 - 11:12 PM UTC
Searchlights (from Bronco) added to SPARK and Rhino mounting:
jwest21
KitMaker: 3,374 posts
Armorama: 3,126 posts
Posted: Wednesday, August 31, 2016 - 11:25 PM UTC
This build is awesome!
kubisz
KitMaker: 978 posts
Armorama: 977 posts
Posted: Sunday, September 04, 2016 - 08:30 PM UTC
Thanks, Jason
Roller coloured:
youngtiger1
KitMaker: 534 posts
Armorama: 344 posts
Posted: Monday, September 05, 2016 - 12:40 AM UTC
Nice work. I wonder if the green part of the rollers are rubber as on tank wheels?
kubisz
KitMaker: 978 posts
Armorama: 977 posts
Posted: Monday, September 05, 2016 - 12:48 AM UTC
I'm pretty sure, that this is some kind of hard rubber. But I'm saying this only after seeing photos, many photos, but photos only
youngtiger1
KitMaker: 534 posts
Armorama: 344 posts
Posted: Tuesday, September 06, 2016 - 02:09 PM UTC
I hear ya. Btw, I don't suppose you have a good reference photo or drawing regarding all those wires from spark and how/where they should be attach to the vehicle? I have seen some photos but yet to find anything specific to the wiring/plumbing connecting. TIA
kubisz
KitMaker: 978 posts
Armorama: 977 posts
Posted: Tuesday, September 06, 2016 - 03:46 PM UTC
On our Humvee forum we've got all You need Please take a look:
http://www.humvee-models.com/viewtopic.php?f=22&t=168
There are some walkaround photos, I think all wires are quite well visible.
kubisz
KitMaker: 978 posts
Armorama: 977 posts
Posted: Thursday, September 08, 2016 - 08:20 PM UTC
Boomerang III (Live Resin):
Last parts in the interior:
- sun covers,
- details of door's handles in the rear bulkhead,
- Rhino and Boomerand controlers (on both side of the radio),
- emergency escape window (VEE) handles:
Jacek_Placek
Gdańsk, Poland
KitMaker: 154 posts
Armorama: 154 posts
Posted: Thursday, September 08, 2016 - 08:50 PM UTC
Fantastic!
