Tamiya Famo Sd Ah 116 trailer and DML Panzer
Giovanni1508
Napoli, Italy
KitMaker: 652 posts
Armorama: 600 posts
Posted: Monday, September 07, 2015 - 07:54 PM UTC
Hi Michael,
Great job so far. I'm following with interest because the same baby is in my to-do list.
Looking forward to see your progress.
airborne1
KitMaker: 915 posts
Armorama: 797 posts
Posted: Wednesday, September 09, 2015 - 03:05 AM UTC
Thanks Giovanni,
Unfortunately it is a slow and methodical task getting the figures, Famo and trailer done.
Near 2 years and a lot of patience .
Michael
airborne1
KitMaker: 915 posts
Armorama: 797 posts
Posted: Thursday, September 24, 2015 - 08:42 PM UTC
Here is the next figure to be painted.
There was a delay as I had been working on Ammo washes on the various panels on the front of the Famo tractor.
Here is the side panel with a Ammo wash to darken the panel to try and create a realism effect.
The figure in the image is the next one to be painted in enamel paints with oil paints for the arms and face .
The figures in the front compartment will be a combination of Vallejo acrylic ,Humbrol enamels and Andrea acrylic paints.This will be to break up the uniformity of no 2 figures being identical .
More to follow on the figure.
Michael
airborne1
KitMaker: 915 posts
Armorama: 797 posts
Posted: Friday, October 16, 2015 - 11:29 AM UTC
Hello,
Here is the kit figure glued together with Tamiya thin and thick glues , the glue is perfect for figures because it welds the plastic components together and there is very little need for filler .
Was a big fan of Revell glue until a few years back and I never look back at using the Tamiya glue .
The upper torso is dremmelled out to allow the hornet head to sit within the Torso .
The figure is then airbrushed in Mig's ammo primer .
Was a Humbrol primer fan for many years although the Ammo product is way quicker to use.
A couple of drops of primer and a drop of thinner and bang away you go .
The Ammo cleaner is the way to go for clean up of the primer after use.
Quick and easy , perfect , and not affiliated to Mig's ammo products in any way ,
just like experimenting with new products .
Once the primer is allowed to dry I then used Humbrol colours
226,31 and 147 for highlights.
The 147 was mixed with 226 and 31 as a high light colour only
The head and arms have been painted in oil paints with a black pin wash for the fingers , eyes,mouth and ears .
5 colours of oil paint , red white yellow ,pink and sienna
A black and grey pastel application was made for the bearded growth area .
This was applied with a fine brush, hard to see in the photo's but it is there .
Tester Glosscote and dullcote had been used for the Tamiya decals for the cap, epaulettes , collars and belt buckle.
Glosscote applied and then set for a couple of hours , maybe a day or more and then the Tamiya decals applied with Mr Gunze mark softener .
Once dry I applied a coat of Tester Dullcote to the cap and uniform only.
I stayed clear of the skin areas because they hold the transparency with the oil paint.
Michael
GazzaS
#424
KitMaker: 4,648 posts
Armorama: 2,248 posts
Posted: Friday, October 16, 2015 - 11:34 AM UTC
I'm building planes currently, but Dang! that looks good.
Best Wishes,
Gary
Thirian24
Oklahoma, United States
KitMaker: 2,493 posts
Armorama: 2,344 posts
Posted: Friday, October 16, 2015 - 06:48 PM UTC
Excellent work!
airborne1
KitMaker: 915 posts
Armorama: 797 posts
Posted: Saturday, October 17, 2015 - 03:32 AM UTC
Thanks Guys
I appreciate your words .
Michael
Stickframe
#362
KitMaker: 1,661 posts
Armorama: 1,202 posts
Posted: Tuesday, October 20, 2015 - 09:33 PM UTC
Hi Michael - great build. With the complexity of it, it looks like you're building several kits at once - nice! I must say, I like the painting technique you're using - like the image above, where you're testing the figure's fit. Fairly clean on the seats and body, but nice wear shown on the floor. Looking forward to more.
Nick
airborne1
KitMaker: 915 posts
Armorama: 797 posts
Posted: Wednesday, October 21, 2015 - 12:10 PM UTC
Thanks Nick,
More figure updates to follow shortly.
With the example photo taken under a flouro light it has made the figure's uniform look a little brighter.
Did not notice it as much until after posting .
The next batch will be slightly toned down or should I say reduced brightness in the uniform appearance
6 more to go ....
Michael
jrutman
KitMaker: 7,941 posts
Armorama: 7,934 posts
Posted: Wednesday, October 21, 2015 - 06:20 PM UTC
Looking good and coming along nicely. I will have to try the Tamiya glue as per your recommendation. The glue I am using doesn't bond very well. Pretty much a bad feature for glue I would think.
J
airborne1
KitMaker: 915 posts
Armorama: 797 posts
Posted: Thursday, October 22, 2015 - 12:05 AM UTC
Thanks Jerry.
Any plastic seems to bond from the Tamiya glues and I still use the Revell glue depending on the application .
The Tamiya thin glue is highly recommended to be used with the Tamiya putty.
Thin the putty down with a the Tamiya glue and use the finer brush to apply around the arms and legs to fill any cracks .
Hope this helps .
Michael
airborne1
KitMaker: 915 posts
Armorama: 797 posts
Posted: Saturday, November 14, 2015 - 05:30 PM UTC
Hello again,
Just a small update on the progress .
Spent a few hows on the aber rifle racks today , still have to glue on the bolt heads at the base of the latch .
Sorry just the 1 photo for now
Michael
swat35
Michigan, United States
KitMaker: 40 posts
Armorama: 39 posts
Posted: Saturday, November 14, 2015 - 07:21 PM UTC
Beautiful work Michael, the figures are very impressive. Your techniques are timeless.
Terry
airborne1
KitMaker: 915 posts
Armorama: 797 posts
Posted: Sunday, November 15, 2015 - 12:21 AM UTC
Thanks Terry ,
Had a short break from the figures for the time being
Had to spend some time to get the rifle rack together.
There was no way I could close in the cab till I get this done .
Michael
airborne1
KitMaker: 915 posts
Armorama: 797 posts
Posted: Saturday, November 28, 2015 - 01:19 PM UTC
Rifles are done, a little more touch up painting and weathering and it's back to the figures.
airborne1
KitMaker: 915 posts
Armorama: 797 posts
Posted: Tuesday, December 08, 2015 - 04:59 PM UTC
Test fitting Engine , troop and cargo compartments.
The Beast comes together for the first time.
Hohenstaufen
KitMaker: 2,192 posts
Armorama: 1,615 posts
Posted: Wednesday, December 09, 2015 - 03:57 PM UTC
Nice job on that figure Michael.The Famo and trailer(previous page)is superb too.
If you are looking to ring the changes with the figures a bit, I think Tamiya made a mistake with their Famo crew. They seem to have confused the Reed Green Drill field uniform with the Denim fatigue suit. These were a cement coloured raw cotton drill outfit, much simpler in design without the chest pockets and no flaps to the skirt pockets. This suit was frequently worn by engineers and mechanics who were likely to be involved in dirty work to save their Feldbluse from damage. Overalls were popular with tank repair crews too, usually grey, although the SS had a camo version that was issued to tank crews. As the war went on the off white denims were often dyed a green grey colour for concealment. Both of these are easy to reproduce by careful carving of the Tamiya figures, or are available from the AM guys; in fact the standing guys in the kit are of course wearing overalls.
airborne1
KitMaker: 915 posts
Armorama: 797 posts
Posted: Thursday, December 10, 2015 - 01:26 AM UTC
Thanks Steve,
Appreciate your words and the figure info.
Michael
M4A1Sherman
KitMaker: 4,403 posts
Armorama: 4,078 posts
Posted: Saturday, December 12, 2015 - 10:31 PM UTC
Thanks Steve,
Michael
LOOKIN' GOOD, Michael. That TAMIYA FAMO & Sd.Anh.116 is one sweet kit! I see that we follow the same techniques and coloring!
I did something very remarkably similar as you are doing; I spent a fortune on ABER PE and resin stowage and updates from other manufacturers for both the Tractor and the Trailer. I replaced the Wheel/Tire assemblies with resin ones, and I used Friulismo Tracks for the Tractor.
I loaded the trailer with DRAGON's Excellent #6713 s.IG.33 auf Fgst. Pz.Kpfw.III (Sfl.), which I enhanced with VOYAGER PE, and Friulismo Tracks.
The FAMO is shot in overall PANZERGRAU with a thinly sprayed "squiggle" camo pattern of a color close to "AFRIKA GRUNBRAUN". The trailer is in overall PANZERGRAU, as is the s.IG.33/Pz.III. I had the early stages of Stalingrad in mind for this project.
It took a long time to reach completion, as I like to bounce around between other projects...
airborne1
KitMaker: 915 posts
Armorama: 797 posts
Posted: Tuesday, December 15, 2015 - 04:59 PM UTC
Thanks Dennis,
Sorry for the late reply .
Yes, then you know how difficult it is to stay committed on a large model.
With all the new models being released it's hard to keep on this tractor and trailer.
It was around this time 2 years ago when I was posting the plastic sprues. The end is close.
Received confirmation the transport box for the Famo is ready for pickup this week. Will post some photo's as soon as it's received.
Michael
airborne1
KitMaker: 915 posts
Armorama: 797 posts
Posted: Thursday, December 31, 2015 - 04:45 PM UTC
Hello again,
The famo crew have been painted in Vallejo acrylics with oil paints used for the face and hands.
The figures are now in the next stage of having the decal collar tabs and shoulder boards applied.A coat of Testers gloss coat has been used to help sit the decals on the figure.
Once the decals are done the next stage is to glue resin hands to the remaining 3 crew figures.
Engine side covers have been detailed and are ready to be glued into position.
The front and sides of the crew compartment has been glued together.
Further work will be required to place the crew figures and equipment in the cab and will be glued to the chassis at a later stage.
Wishing you all a happy 2016
Michael
Thirian24
Posted: Thursday, December 31, 2015 - 08:38 PM UTC
Very nice work.
Paulinsibculo
Overijssel, Netherlands
KitMaker: 1,322 posts
Armorama: 1,239 posts
Posted: Thursday, December 31, 2015 - 09:02 PM UTC
beautiful build! thanks for sharing.
airborne1
KitMaker: 915 posts
Armorama: 797 posts
Posted: Friday, January 01, 2016 - 04:03 PM UTC
Thanks Guys
Michael
dhines
Nova Scotia, Canada
KitMaker: 407 posts
Armorama: 373 posts
Posted: Thursday, January 07, 2016 - 07:26 PM UTC
Great looking Famo and figures Michael. Cant wait to see the trailer come to life. Keep up the good work. I am looking forward to your next update.
