removing acrylic paint
SFModeller
KitMaker: 151 posts
Armorama: 96 posts
Posted: Friday, July 22, 2011 - 06:35 AM UTC
Hi. Has anyone here successfully removing a bad paint job from the model ? I messed mine up and would like to start over again. I did a search on google and people are recommending from Windex to oven cleaner to soak the model in and use an old toothbrush to remove the old paint. Anyone here knows which works best ? TIA.
Thanh.
parrot
KitMaker: 1,606 posts
Armorama: 1,580 posts
Posted: Friday, July 22, 2011 - 07:11 AM UTC
Thanh,
I have never fully stripped a model of paint,but I would also reccomend Windex.
I and many others use it to clean our air brushes.From my experience with it,It would be best to completly spray it and wait 10 or 15 minutes.Most paint will probably start to drip off.Wipe off what is left.Repeat as many times you have to.
It's only a theory but I do know Acrylics hate Windex.
Hope this helps.
Tom
pseudorealityx
Georgia, United States
KitMaker: 2,191 posts
Armorama: 1,814 posts
Posted: Friday, July 22, 2011 - 07:55 AM UTC
I recently used windex on an entire Tiger turret that had been sprayed with Tamiya. Worked well, on plastic, metal, and resin.
Go that route. Works well, and easy.
GALILEO1
Maryland, United States
KitMaker: 1,794 posts
Armorama: 1,431 posts
Posted: Friday, July 22, 2011 - 07:59 AM UTC
I definitely third Windex! It's THE best thing to completely remove acrylic paint from a model. I stripped several models using it and never a problem. Just make sure you rinse it with water afterward and you're all set.
Rob
SFModeller
KitMaker: 151 posts
Armorama: 96 posts
Posted: Friday, July 22, 2011 - 09:20 AM UTC
Thanks for the replies. I definitely will stop by a supermarket and get a bottle of Windex on my home today. Thanks again.
Thanh.
rdwing64
Arizona, United States
KitMaker: 45 posts
Armorama: 42 posts
Posted: Friday, July 22, 2011 - 04:21 PM UTC
Soak it in windex . Awesome!
SHarjacek
Croatia Hrvatska
KitMaker: 977 posts
Armorama: 553 posts
Posted: Friday, July 22, 2011 - 05:46 PM UTC
is there a European version of Windex?
Kind regards.
captnenglish
KitMaker: 1,184 posts
Armorama: 770 posts
Posted: Friday, July 22, 2011 - 06:16 PM UTC
Windex or PineSol work for me
tankman3rd4id
Missouri, United States
KitMaker: 32 posts
Armorama: 27 posts
Posted: Friday, July 22, 2011 - 06:23 PM UTC
guys i have found a great paint stripper as well . its called wheasleys whitewall cleaner. you pour it in and soak your model 24 hrs later you scrub it with a tooth brush and then rinse. you will have a very clean model.
WARDUKWNZ
Auckland, New Zealand
KitMaker: 1,716 posts
Armorama: 1,638 posts
Posted: Friday, July 22, 2011 - 08:14 PM UTC
OK time for my two cents worth and i'm gonna be different lol ..oven cleaner is all i use to strip my old paint ..even removes chrome ,,i have found to strip everything down to the smallest detail ..takes about an hour to hour and a half and its done ..most will wash off under cold water and only needs like scrubbing with a soft tooth brush ..dont seem to hurt tires but then i always remove them anyway ..wont hurt clear plastic ,,never use the foaming oven cleaner..its useless ..only the nonfoaming oven cleaner ..that should give you fellas something to think about lol
SFModeller
KitMaker: 151 posts
Armorama: 96 posts
Posted: Saturday, July 23, 2011 - 04:48 PM UTC
I gave it a try this afternoon and Windex works wonder. Thanks everyone for your suggestion.
Thanh.
jon_a_its
KitMaker: 1,299 posts
Armorama: 1,104 posts
Posted: Sunday, July 24, 2011 - 10:56 PM UTC
Kind regards.
Windolene WITH ammonia, getting hard to find in the UK though....
Easy_Co
KitMaker: 1,933 posts
Armorama: 985 posts
Posted: Sunday, July 24, 2011 - 11:19 PM UTC
be careful with oven cleaner if you have P.E. its eats up super glue
Spiderfrommars
Milano, Italy
KitMaker: 3,845 posts
Armorama: 3,543 posts
Posted: Sunday, July 24, 2011 - 11:54 PM UTC
Kind regards.
http://www.dambiro.de/CHANTECLAIR-Marseilles-Universal-Grease-Remover-750ml
Sven I use this one and is incredibly effective. You have to soak the model overnight or more. Paints will strip away easily
....yes that's true
jon_a_its
Posted: Monday, July 25, 2011 - 10:29 PM UTC
Kind regards.
....yes that's true
Fairy Power Spray (uk) if you have to shift enamel, It's still an oven cleaner, but not so harsh....
Tesco's own brand value cleaner (with ammonia) has been recommended for Acrylics but I have NOT tested this yet!
Joel_W
AUTOMODELER
KitMaker: 11,219 posts
Armorama: 1,143 posts
Posted: Tuesday, July 26, 2011 - 02:40 AM UTC
I've also used Windex with ammonia to strip acrylic paint off of plastic. The best part of the deal is that my wife uses it all the time for cleaning glass, so I never have to worry about having it on hand.
For stripping chrome, which I've never seen on any armor model, household Clorox takes care of it.
Smokeyr67
Australian Capital Territory, Australia
KitMaker: 144 posts
Armorama: 136 posts
Posted: Tuesday, July 26, 2011 - 07:52 AM UTC
Doesnt remove lacquer.
Kharkov
KitMaker: 181 posts
Armorama: 175 posts
Posted: Tuesday, July 26, 2011 - 08:14 AM UTC
Brake fluid seems to shift pritty much everything, and works best if you immerse the entire part in the fluid rather than just coating the surface, brake fluid also eats ca glue.
Drawback with brake fluid though is its not very nice stuff, and I dont think the newer versions, ie dot 4 n 5 are as potent as the good old dot 3 stuff that I dont think you can buy anymore.
cementshoes
KitMaker: 69 posts
Armorama: 34 posts
Posted: Sunday, January 20, 2019 - 03:55 AM UTC
I botched a clear coat so I tried windex which I think would be the safest and least evasive and it works amazingly.
Armorsmith
KitMaker: 1,037 posts
Armorama: 974 posts
Posted: Sunday, January 20, 2019 - 05:26 AM UTC
Break fluid does a great job but it will attack resin. I learned the hard way.
TopSmith
KitMaker: 1,625 posts
Armorama: 1,550 posts
Posted: Monday, January 21, 2019 - 05:41 AM UTC
I have also used 90% isopropyl alcohol I got from the drug store. I let it soak for an hour and brushed off all the paint.
When experimenting, always start with the least aggressive and move to the more aggressive products.
Caution: Never use lacquer thinner on plastic to remove paint. Unhappiness will follow.
paulo
Wales, United Kingdom
KitMaker: 72 posts
Armorama: 66 posts
Posted: Tuesday, January 22, 2019 - 04:57 AM UTC
I use Clean Slate from VMS (Vantage Model Supplies)- very clean and quick to use.
