Cleaning Your Airbrush
j76lr
KitMaker: 1,054 posts
Armorama: 1,039 posts
Posted: Saturday, August 06, 2016 - 10:33 PM UTC
I also use a jeweler cleaner . it tiny microscopic bubbles created by sonic waves . works great in between breakdowns .their pretty cheap about 25-30 usd on amazon
j76lr
Posted: Monday, August 08, 2016 - 12:36 AM UTC
Be careful with ultrasonic cleaners, it took the plating off my H$S nozzles! They still work, but the chrome protection was taken off them.
what do you
use Scot ? I usually only use acrylics and use windex so far no problem !
chakie
Turku ja Pori, Finland
KitMaker: 18 posts
Armorama: 18 posts
Posted: Sunday, October 23, 2016 - 03:45 PM UTC
I've used my AB for two months now with Tamiya colors and had no real issues that weren't caused by me not knowing what I did. I always strip the brush and clean with some normal hardware store thinner and sometimes with Tamiya's AB cleaner. No issues so far.
However, if I want to use some Vallejo colors, what should I clean with? I used their gray base coat the other day and when cleaning with thinner it just turned into gunk and I had to strip the AB down and thoroughly clean with paper and those pointy thingies with cotton at the end. What should be used to clean Vallejo colors from my AB? Distilled water? Or does Vallejo have some own solution? Based on some googling there doesn't seem to be any clear answer and people use all kinds of thinners, spirits and whatnot. But there ought to be something that can be used that I can get in a basic hardware store which does not cost an arm and a leg for 10 ml.
Armored76
Bayern, Germany
KitMaker: 1,615 posts
Armorama: 1,500 posts
Posted: Sunday, October 23, 2016 - 04:54 PM UTC
I'm using plain tap water to clean the airbrush after Vallejo and Revell Aqua paints. Using IPA seems to turn the Vallejo paints into the goo you mentioned.
alewar
Canelones, Uruguay
KitMaker: 773 posts
Armorama: 765 posts
Posted: Sunday, October 23, 2016 - 06:13 PM UTC
Hi, my ultrasonic cleaner have cicles of 3 min each. I really have not seen very best results, so which the best session time?
I use tap water and detergent, I can use windex instead?.(I use acrylics)
Regards from the south
Alvaro
M4A1Sherman
KitMaker: 4,333 posts
Armorama: 4,078 posts
Posted: Sunday, October 23, 2016 - 06:43 PM UTC
Hello all! I have been modeling for 30 or so years and have been using an airbrush for about 20 of those years. After every use I totally take apart my trusty Badger 200 singe action airbrush and give it a total clean up. 75% of the time I use acrylics. I have been told by some modelers that Im nuts especially with acrylics, and that theres no need to do this EVERY time but rather every 5th or so time. Many opinions are to just shoot my cleaner of choice through and then clean H2o and be done with it, unless there is a clogging issue. What do you think or do? Thanks guys!
I personally use petroleum-based enamels and lacquers in ALL of my airbrushing. I adhere strictly to breaking down my airbrushes and cleaning them in a four-step process after EACH color, thereby saving myself headaches, later on. Some of you may think this un-necessary, but it works for ME, and that's the way I'm going to keep on working...
1) Break down and clean the parts in fresh airbrush thinner, using "pipe-cleaners" to help the process
2) Soak the parts in fresh airbrush thinner for about 10 minutes, as added "insurance" against cross-contamination
3) Dry and soak the parts in Isopropyl Alcohol for another 10 minutes to remove any residue of the airbrush thinners, let dry thoroughly
4) Re-assemble the airbrush for the next airbrushing/color-session
Works every time... Again, this is just my personal preference...
I own and regularly use my four airbrushes, one of which (PAASCHE H-1 fine-tip single-action) is STRICTLY for metallic and "metalizer" paints and lacquers. The other three are for my conventional enamel and lacquer paints; a second PAASCHE H-1 fine-tip single-action and BADGER 200 fine-tip single-action for general airbrushing, and lastly, my BADGER 200G with ultra-fine tip and top-mounted integral color receptacle, which I use for detail work, "corrections", and the finer-types of "mottled" camouflages, as seen on my 1/48 WWII "Axis" Fighters, (German, Italian, and Japanese)...
SEDimmick
KitMaker: 1,745 posts
Armorama: 1,483 posts
Posted: Sunday, October 23, 2016 - 06:46 PM UTC
what do you
Its been a while, but I think I was using Simple Green in it.
Vicious
KitMaker: 1,453 posts
Armorama: 1,067 posts
Posted: Monday, October 24, 2016 - 12:53 AM UTC
When you say "fresh airbrush thinner" what thinner you talk about?...
wedgetail53
KitMaker: 647 posts
Armorama: 618 posts
Posted: Monday, October 24, 2016 - 02:50 AM UTC
G'day Jan
Vallejo have their own thinner and airbrush cleaner. Do not use other thinners with Vallejo paints - they turn into something the consistency of chewing gum.
The proprietary cleaner does a good job.
Regards
Rob
Barrikadyzavod
Barcelona, Spain / España
KitMaker: 21 posts
Armorama: 21 posts
Posted: Sunday, November 13, 2016 - 04:51 PM UTC
Maybe this can be useful:
https://www.youtube.com/watch?v=6yjCpkmyOGk&feature=youtu.be
SSGToms
Connecticut, United States
KitMaker: 3,505 posts
Armorama: 2,998 posts
Posted: Friday, June 30, 2017 - 06:45 AM UTC
G'day Jan
Regards
Rob
Iwata Medea airbrush cleaner also works excellently on Vallejo paints.
